Old Wed 21 September 2022, 15:01
Mcmoo
Just call me: McMoo
Norfolk
Speeds.
Evening All,
I'm really interested to hear what feeds and speeds people are using to get an understanding of what's happening with my machine, and to see if I can improve on what I've currently got.
I've been machining some 15mm ply, and slowly ramped up my speeds, suddenly my whole sheet had 'ghosted'
Tried re-homing and running an air cut,.ended up binning 3 sheets of material and stripping down a gear box and checking grub screws were tight and replacing a stepper motor.
Lost a day of machine time, and well felt somewhat defeated.
Currently running a 2.2kw water cooled spindle, had a 6mm twin flute low helical cutter, running multiple passes at about 15kish rpm , I've been higher and lower and seem to be able to get about 3500 to 4000 mm per minute, using uccnc.
Many Thanks
Starting out to actually cut something - cutters, speeds, depths, directions, etc. Richards General - MM Operating 22 Tue 09 July 2013 03:02
Speeds, Feeds, Materials and Bits smreish Cutting various materials - bit selection, feeds, speeds 65 Sun 11 March 2012 08:01
Feeds and Speeds #84 - Mortara, Italy vanja.ivancic MechMates already cutting 36 Mon 04 July 2011 04:53
Cannot get good jog speeds - first thought PS voltage too low, then current error kwang90020 Troubleshooting 11 Tue 17 March 2009 13:28
Convert dimensions, speeds, forces, temp, etc from metric to inches etc. Kobus_Joubert Utility software 2 Tue 19 August 2008 17:10
