Old Mon 21 September 2009, 07:10
vanja.ivancic
Just call me: vanja #84
mortara
Italy
Feeds and Speeds #84 - Mortara, Italy
Thank you all for the help, especially Gerald for drawings.
I am Croatian from Opatija but I liv in Mortara - Italy (20 years). I have started last Christmas with MechMate and the reason why I have not write in this forum is my bad knowledge of English. I mus use the vocabulary when I reed the messages. Fortunately there are many photos in.
I am architectoni modeler and this is the reason why I want to built this machine. Not for cutting but for modeling. I am good in working wood and this is the first time I working iron. ( My welding makes cry) I am very sorry because my experience will not be much useful.
Technical data:
Mech Mate 150 x 200 cm
X and Y rails - V-guides on iron profile ( Pacific Bearings, v-guides + wheels + bushings cost me app. 600 €)
Racks from Chiaravalle
Some photos:
I have found this problems: On the spider plat the wheel holes are distant 132mm app. and that was to short for me. look photos:
Fabricas suggestion: Weld the screw in the holes, filing, drilling new holes and taping.
To put surface in plane
Glass control and paralel control
Everything is smooth and perfect
(I like the sound when the wheels rolling on guides)
Then I find that last 6 holes on the gauge plate not correspond with holes on the z-slide tube. I think the quotes are wrong???
Now I have to do with motors and electricity. HSD offers me a good price (480€) for MT 1073 Y6162Y0010 , 1.5 kW 220 V 18000 rpm. Am I wrong???
In my laboratory is instsled only 3.5 kW.
Its just 1 month I study the electrical components (in free time), and I want be sure in configuration which is good for me. I don't need speed but good finish. I have think about 24 gear pinion, Oriental motors 1:7.2, gecko drives 203, PDM 122.
I don't know how t instal E-stops and how to conect them, imagine for the other components. It will be a good school. I am very proud for the things I have just done. Thank you all and best wishes.
Panorama from my home in Croatia
Old Mon 21 September 2009, 07:30
Vanja,
Welcome to the forum.
Your build looks great! Nice job.
Please continue to share your progress with us. Your experience may help someone else. You never know.
Old Mon 21 September 2009, 07:57
Welcome Vanja! Your English is quite okay - I understand you. Sorry about the drawing problems, I will check them. Your progress is great!.
Is your house in Opatija available for holiday rent?
Old Mon 21 September 2009, 08:05
vanja.ivancic
mortara
Italy
Yes it is. I can send you soe photos of the place if you want!?!
Old Mon 21 September 2009, 16:31
kooskoek
Just call me: Dave
Centurion
What a view,wow
Old Mon 21 September 2009, 18:26
Welcome aboard and yes, you may just bring more useful experience than you think, all work is good to see & compare too.
Plus if you participate in this forum, your future usage & experience with your MM will be useful and good source to this fun community.
Congratulation on your progress and please come back some more photos as you progress !
Best of luck
Old Sun 27 February 2011, 08:25
vanja.ivancic
mortara
Italy
control box and mach3
This is what I have done last weeks after one year pause.
Attachment 11318
power sopply 2x 25 V parallel wiring, two condensers 22000uF and 10000uF.
I have try to take 9 V from toroid makeing 22 loops around. First time I have misurated the voltage it was 9 V. When I fixed it on the iron plate I have misurated again and the voltage was 6 V. Than I decided that it is better not
to risk and I buy a 5 - 9 - 12 V transformator.
I have orderd a new computer for move the motors and I ask the vendor to put on one parallel port. He puts me on PCI parallel board Kraun KR.g5 sunix 1888 with two parallel ports. It was monday.
How to find the port adress?
First problem was that my PCI bord was not enabled PnP in BIOS.(Bios-advanced-PCI PnP- plug and play o/s [YES]). Than I find te adress here:
It was wednesday.
Second problem was that short conection E-stop was very bad and at the moments make false alarm on mach3. I have changed the wire(number 3 above). Than I forgeted to enable charge pump on pin 17 in MACH3.(I've think I dont need it because "I have not any pump on my machine".) I have spend days on google search to find the solution but the solution was in MechMate forum. The led (number 2 above) on pmdx122 is E-stop. If it lit motors dont turn. The led (number 1 above) is the heart of pmdx122. If it don't lit nothing moves.
Friday finaly I turn first motor.What a lovely sound it has.
Thanks to all !!!!!!
Old Sun 27 February 2011, 09:08
Welcome back Vanja!
Old Sun 27 February 2011, 13:03
Khanid
Just call me: Khanid
Lipik
Croatia
Nice to see more Croatians here!
@Vanja
Pogledaj nas pocetak rada na MM plazmi pod rubrikom pocetak gradnje!
Old Sun 27 February 2011, 14:35
vanja.ivancic
mortara
Italy
vec vidjeno.Puno citam, malo pisem (slab engleski)
I hope you help me to translate some things when I find difficulties
Old Sun 27 February 2011, 14:37
Khanid
Lipik
Croatia
Nema problema, samo javi kada te nesto muci!
Old Sun 27 February 2011, 18:08
Nice to hear from you Vanja!
Old Mon 28 February 2011, 13:29
vanja.ivancic
mortara
Italy
Thanks for your contribution
Old Sat 05 March 2011, 13:58
vanja.ivancic
mortara
Italy
two tipe of pinons - 24 and 35 teeth
I wontn to put 35 teeth pinon but I can because is to big. My rail is to high.
Can I alarge the hole on the picture above??? I need only 3mm!!!
Or maybe is better to change the design of motor plate?!?
Old Sat 05 March 2011, 14:11
I see no reason why you can't extend that slot; it's a guide and it isn't load bearing. In fact, although it wouldn't be as pretty, you could likely extend it right to the edge of the plate.
Two other possibilities: Cut off the tab for the other (hinge) bolt, and weld it back on a little longer, or even simpler - drill a new hole in the gantry below the existing hinge bolt hole.
Old Sat 05 March 2011, 14:43
vanja.ivancic
mortara
Italy
The last solution is the simpliest and probably the best,
Old Sat 05 March 2011, 15:21
On MM #5 I had to relocate the pivot hole on the gantry to allow for larger pinions on a special project. Easy to do - just remember to countersink that hole!
Old Sat 05 March 2011, 21:34
I had the same problem on MechMate #6. I measured 28mm hight from the inside of the angle iron. The slotting of the motor mount plate took care of the problem.
Old Sun 06 March 2011, 05:18
vanja.ivancic
mortara
Italy
Yes, cause there is not space to do the other hole in the gantry. Than is difficult to countersink the hole now.
Other problem i have seen is to hold sloted screw head when you mount the motor.
Maybe this can be solution for pinons up to 36 teeths
Old Tue 14 June 2011, 09:24
vanja.ivancic
mortara
Italy
Seems it work!
Seems it work !!!!!!!!!!!!!!!
http://www.youtube.com/watch?v=3oeeFKJqf2w
Old Tue 14 June 2011, 09:37
Vanja, Youtube is still loading your file . . . . .
Old Tue 14 June 2011, 12:13
don't know if it matters but with the end letter "w" small it works
Old Tue 14 June 2011, 20:55
Yes, it works and looks great - well done!
Old Wed 15 June 2011, 02:23
vanja.ivancic
mortara
Italy
Fortunatly there are meny other things to do (spindle,limit swiches etc).
Mech Mate is never finished....
(Hvala Danilo)
I have a litle problem with Mach blue probing.Zero plate works but center finding seems to work with inches insted of mm. Maybee someone have idea how I can change the program? I have not find solution in mach forum and cnc forum.
Old Wed 15 June 2011, 03:25
kaartman
Just call me: Koning #20
Abu Dhabi
United Arab Emirates
Congratulations Vanja, enjoy playing with the new toy.
Old Wed 15 June 2011, 05:27
Be sure to download latest version
http://www.machsupport.com/screens/M...by_Big-Tex.zip
It should have the metric/inch check with GetOemLED(801) in tool zeroing, but I also don't see it it the PROBES section for center finding.
Here is the screenset which one user on cnczone changed to metric, try this one but be sure to have a finger on a RESET button if anything goes wrong. just copy this file to Mach directory and load it View->Load Screens.
cnc.rs/mechmate/MachBlue_probing_metric_version2.set
this is the thread on cnczone where I found it
http://www.cnczone.com/forums/mach_w...big-tex-7.html
Also if you want to check the button script, go to Mach3 menu... Operator->Edit Button Script and click on a button you need.
Pozdrav!
Old Wed 15 June 2011, 05:50
I think that this should solve it faster:
go to Operator -> Edit button Script , click on a button for center finding, look for a line that says
" XNew = Xcurrent - 3 'probe 3 inches to left "
just change the number 3 with amount of millimeters you need, you have 3 more occurrences of this command, for x+ , y- and y+
also edit other buttons to you liking !
Old Wed 15 June 2011, 12:02
vanja.ivancic
mortara
Italy
I will try tomorow!
Old Wed 15 June 2011, 15:36
Nice to see another MechMate in action !! You get number 84.
Old Wed 15 June 2011, 18:47
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Congratz! Now the real work begins
Tim
Starting out to actually cut something - cutters, speeds, depths, directions, etc. Richards General - MM Operating 22 Tue 09 July 2013 03:02
Speeds, Feeds, Materials and Bits smreish Cutting various materials - bit selection, feeds, speeds 65 Sun 11 March 2012 08:01
hello from Italy (Naples) federicodimeo Introduce yourself and start planning 1 Mon 25 October 2010 11:24
Hello to all from Italy Biribago Introduce yourself and start planning 2 Tue 06 April 2010 21:58
Ciao from Italy ! silverdog Introduce yourself and start planning 15 Thu 04 June 2009 12:37
