Old Mon 20 October 2014, 15:36
Duds
Just call me: Dale
Canberra
Adaptor plate or direct mount air spindle?
Hi folks, I have a cheap air cooled spindle. The motor just has has a massive aluminium extrusion that it is pressed into. It has a matrix of tapped mount holes but I'm tempted to just drill the two holes for the dowel pins and fit a stud for the through hole mount on the z slide.
Or, should I create an adaptor plate with matrix of screws to hold the spindle and dowels and stud for the z slide.
Old Mon 20 October 2014, 19:37
Best guess
My best guess, and what I would do, but you must make your own decision [sorry, software guy so weasel words are required] ...
My suggestion is, if you think you might want to swap spindles, put it on a mounting plate so you could swap spindles (to router, air-drill, other spindle, etc), is the best and most flexible solution.
If you are only ever going to use this one spindle and don't plan on ever changing, mount it directly, to save a little cash.
Still, preferred method would be mount it to a replaceable mounting plate, IMHO.
Plasma - direct drive - Gilbert Arizona Vern2 Miscellaneous / General / Whatever / Catchall 61 Tue 02 August 2011 08:20
Quick release plate for spindle ... silverdog 50. Toolheads 2 Sat 18 December 2010 08:04
2.2kw Spindle Mount??? ahe_1990 50. Toolheads 6 Sun 19 September 2010 22:19
Direct motors 4Nm and 6,8Nm tomasptacek Motors & their mountings 0 Wed 26 May 2010 02:25
how do I mount a router base to the z plate? kanankeban 40. Z-Slide 2 Fri 06 March 2009 01:43
