Old Sat 08 January 2011, 01:56
smeagle
Just call me: smeagle
Bucharest
hello from Romania
I want to build a CNC router to mill wood and plasma cutting , and the table will have 2500x1500 mm and the work surface it will be probably 2100x1300 mm , it will be the schelet of the masine with gantry an y and Z axis maybe the 4th ax latter , and the work table it can remove because it will be hard to put the steel sheet on it , I intended to use 3 stepper motor for the x axis is abut 12 Nm or 1700 Ozin , for Y axis is 8,5 Nm or 1200 Oz in and for the Z axis 3 Nm or 420 Oz in , for z axis I willm use screu , and axis with linear ball bearings , for gantry and Y axis I will use pinion ang gear to the motor to pinion of 1:2 or 1:2.5 and ballbearings roll like normal MM cnc but with precizion axis instead of the corner profile , now I am making just the project and wait to get some mony to start , I found everything here in Romania , the motors , the drivers and others , the precizion shafts I'll buy and others I'll manufacture in my workshop , the aproximate costs are under 3000 euros .
I have good knowlege with Catia V5 and G code but nothig about mach3 or art cam and other programs ...
Old Sat 08 January 2011, 08:04
Welcome to the group. Just read on in the forum as we have a lot of good information on what is needed to build a MechMate !!!
Old Sat 08 January 2011, 09:00
fanefane
Just call me: Stefan #73
Baia Mare
Parca nu prea erai multumit de acest proiect vroiai sa faci alceva , cind am zis sa studiezi un proiect testat , facut de multi si inbunatatit !
Succes!
Old Sat 08 January 2011, 09:21
smeagle
Bucharest
dar nu am zis ca nu sunt multumit de proiect , doar ca sunt unele lucruri pe care le voi schimba ...cum ar fi sinele unde voi folosi tot role dar pe bara de fi20 si la carucior , in rest la cremaliera m-am gandit prima data apoi am vazut acest proiect prezentat de tine , nu in linii mari va semana ....
Old Sat 15 January 2011, 16:51
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Smeagle: Welcome to the group. It is a good adventure and a lot of fun thanks to the always helpful members.
Old Sun 16 January 2011, 06:58
smeagle
Bucharest
hello jehayes , I will make my cnc but a little one now but on the same principal , with rack and pinion , with steppers , and it will have 350x300 mm workatable , and most important to start learn the soft artcam and mach3 ...
Carved Walnut Table #73 - Baia Mare, Romania fanefane MechMates already cutting 111 Mon 14 July 2014 13:04
Greetings from Bucharest, Romania rolix Introduce yourself and start planning 6 Wed 29 December 2010 15:29
Hello, from Romania omumaro Introduce yourself and start planning 1 Sun 12 December 2010 09:57
A little confused...please help with list of components for Romania! Claudiu 60. Wiring & Cable Management 4 Wed 01 July 2009 01:47
Greetings from Romania Claudiu Introduce yourself and start planning 3 Fri 26 June 2009 21:43
