Old Sat 16 January 2010, 08:04
fanefane
Just call me: Stefan #73
Baia Mare
Carved Walnut Table #73 - Baia Mare, Romania
Hi Gerald and all Mechmate builders!
My name is Stefan and I’m from Romania – Baia Mare. I’m sorry if my English is not so good!
I would like to take the opportunity to thank Gerald for this excellent forum and the idea to share wealthy information.
Until now I’ve read all the articles about how to build a MM from this forum.
My hobby is woodworking.
Well now I am ready to start to build the MechMate
I´m going to use my MM mostly for furniture, ornamentals.
Work area : 1220 x 2440mm (4' x 8')
The stepper motors 34HS9801
Stepper drives Gecko 203V, bob PMDX-122
I have Power Supply transformer with 28 V AC secondaries 300 – 400 VA.
3:1 belt reduction, 16 tooth pulley -48 tooth pulley , the belt is a 295-T5-16 ;
Rack - Module 1 , pinion 26 teeth ; http://www.chiaravalli.it/home/pdf_ita/CREMAGLIERE.pdf
Future upgrade : 4th axis
Old Sat 16 January 2010, 10:16
Claudiu
Just call me: Claus #43
Arad
Bine ai venit. Sa ai noroc si distractie cu MM!
Nice title you got there...get yourself some garlic!
Old Sat 16 January 2010, 18:01
Sherman McCoy
Just call me: "Krasch"
Portland,OR
'bună dimineaţa!' Stefan. Is it true that the best wood workers in all of Europe are from Romania?
Old Sun 17 January 2010, 01:39
Claudiu
Arad
...after they own a MM
Old Sun 17 January 2010, 08:17
gixi
Bucharest
Welcome aboard ! Give me a message with your phone number .
Marius
Old Sun 24 January 2010, 05:54
fanefane
Baia Mare
Hi Krasch, you're right they are good carpenters in this area - Maramures!
I did this furniture 10 years ago, when none dreamed of MM….
If I had one then I think it would be more artistic.
When I’ll finish my MM, I hope to do something nice !
Old Sun 24 January 2010, 06:22
Very nice Stefan. It looks like all solid wood. Did you make the inner parts of the doors FLOATING / loose or did you glue it all together? I am asking bacause I was at my local woodworkers meeting on Wednesday evening and an expert had a talk about using solid timer in this matter. He was going on and on about making a floating or loose construction so that when the wood move, it does not produce cracking.
Old Sun 24 January 2010, 07:22
gixi
Bucharest
Very nice ! I'll visit you this spring to take some lessons from you .
Marius
Old Sun 24 January 2010, 10:06
fanefane
Baia Mare
The interior parts of the doors are separately applied to the back channel, do not stick them because the wood works and you need to allow expansion or contraction, otherwise it will crack.
Old Sun 24 January 2010, 10:57
http://en.wikipedia.org/wiki/Frame_and_panel
Old Tue 26 January 2010, 11:12
Johannescnc
Just call me: John
Hannover, DE
Germany
Welcome Stefan. Ce mai faci? I have friends in Oradea. I have been there many times. I have seen some excellent wood work too. and what is most impressive is the tools that were used... But I know a pretty good woodworker in Germany too
Old Mon 12 April 2010, 04:51
fanefane
Baia Mare
I wanted to buy Stepper Motors 34HS9801 but shipping is very high:
34HS9801 $ 55.00/pcs, ---------------- 4pcs $ 220.00
Express Freight Charges ---------------------- $ 300.00
PayPal surcharges (5%) ---------------------- $ 26.00
------------------------------------------------- SUM - $ 546.00
I want to buy these stepper motors similar to Deitech Co. 86HS9801., Ltd, I hope these are good:
The FOB price for 86HS9801 is USD48.00, 4 PCs to ship to Romania, the DHL freight is USD160, USD352 so totally it cost for you to get 4 pcs in the door.
What do you say, are these as good as the MotionKing's?
Old Mon 12 April 2010, 09:51
I use 86HS9801, can't comment on MK motors as I never have any.
Old Mon 12 April 2010, 10:18
I had the same problem.....freight cost more than the steppers...., but I am happy with my 9801's....nearly 2 years of use ... playing with them.
Old Mon 12 April 2010, 14:07
gixi
Bucharest
You should call me first.... There is a shop near me with everything you need. They don't have Oriental Motors but you should try their stuff. Most important is the service and 2 years guarantee. This is a very well known shop in Bucharest for electronics.
Check their site http://www.conexelectronic.ro/produse.php?id=459 and if is OK I'll go there to make the shopping for you.
Call me tomorrow.
Marius
Old Tue 20 April 2010, 01:56
niubila
Just call me: nicubila
tm
Hi...si salut
I am looking for a CNC workshop to move our production from middle east to romania. Searched for a while but most of the routers we found are just 8*4, too little for us, we need working area min 3000*1540mm (10*5).
I saw here many mentioning about such workshops, and was wondering if any can recommend a good and serious having such a machine, would be very helpful. Some basic requirements:
- 3000*1540 working area
- vacuum table
- at least 25k rpm
- good planarity of the table for all the surface (worst case scenario, the table needs to be resurfaced)
if any of you has an idea about such machine, please et me know. or if any can build and run such a machine, would be ok too, we can discuss details and be very flexible.
thanks
Marius
Old Tue 20 April 2010, 06:04
fanefane
Baia Mare
Perhaps Claudiu, dimensions of your MechMate is 2510x1910 mm
http://www.mechmate.com/forums/showt...?t=1873&page=5
Old Tue 20 April 2010, 06:56
niubila
tm
almost there...
but as mentioned, the parts has to be cut out of a 3*1.54 sheets, so it won't do it. any suggestions? what door to knock?
Old Sun 13 June 2010, 10:02
fanefane
Baia Mare
Meanwhile, I've been working on some other things to get money.
I started the construction and made the first purchases.
I've bought the stepper motors from Deitech http://www.driver-motor.com . They came really fast and had good prices.
Old Sat 19 June 2010, 10:17
Stefan - how is the quality of the racks from Deitech, or did you get them locally??
Old Sun 20 June 2010, 05:10
fanefane
Baia Mare
Irfan, what are the sizes of the aluminium plates that are you using for axis Z?
You used linear size for axis Z 25mm thk slides. Can I use 20mm ones?
I have bought the racks from a local dealer http://www.chiaravalli.it/home/pdf_ita/CREMAGLIERE.pdf. They seem really good.
By the way, what program do you use to make 3d modeling of the MechMate (http://www.mechmate.com/forums/attac...1&d=1259410297 ) ? SolidWorks? Thanks.
Old Mon 21 June 2010, 21:40
Hi Stefan, yes you can use 20mm rails, I just used what were available, the right sizes would be the ones Ken used - mine were experimental and Ken refined those, PM me your email id and I will find out from Ken what he used as final plate sizes and email it to you.
yes thats solidworks, and the main models are from PEU
Old Mon 21 June 2010, 22:44
http://www.mechmate.com/forums/showt...?t=1885&page=9
look at Ken's thread on the above link
Old Wed 23 June 2010, 13:14
fanefane
Baia Mare
I started the construction.
Working size: 1570 x 2530 mm
Old Thu 24 June 2010, 07:22
Isn't it wonderful to finally get your hands dirty after all the preparation! Good progress!
Lost my file in a bad crash... I'll find time redraw & post my Z-slide drawing.
Old Sun 27 June 2010, 09:26
fanefane
Baia Mare
Thanks Irfan and Ken for the infos. I made a slow progress. I've got rid of the dirty work and jumped to the painting
Old Wed 30 June 2010, 06:06
fanefane
Baia Mare
The whole family waited for the construction to be ready. It became really solid.
And some homemade foots. They are made from rubber.
Old Wed 30 June 2010, 07:27
qroger
Just call me: Roger
Matthews (North Carolina)
[QUOTE=fanefane;43539
And some homemade foots. They are made from rubber.[/QUOTE]
Everybody probably knows already but that foot material is old conveyor belt from rock quarry or such. Also good to put in your horse trailer for the horses to stand on! Don't forget if you are cutting rubber, it is easier when it is wet.
Roger
Old Wed 30 June 2010, 08:10
Looking GOOOOOOOOOOOD !
Old Wed 30 June 2010, 08:27
daniel1557
Just call me: Dany
Gujarat
wow good work looks neat !
Painting in V-Carved (engraved) grooves baseball43v3r Miscellaneous / General / Whatever / Catchall 8 Thu 05 April 2012 03:20
Carved Coat Rack Castone The Show Room 12 Sun 10 January 2010 23:14
3d Elk in walnut with video! Greg J The Show Room 13 Mon 10 August 2009 06:50
3D carved Central ornament javeria The Show Room 10 Mon 03 August 2009 15:50
Engraving text - single line fonts vs. 3D carved Marc Shlaes General - MM Operating 3 Tue 19 February 2008 07:03
