Closed Thread
Old Tue 30 November 2010, 03:23
same79
Just call me: same
fsdf
Selecting Stepper motor controller IC
I am a mechanical engineer and would like to build CNC machine. But for now, I want to know, which stepper motor controller IC I should select. Please help me. I want to use only a simple chip or IC. I want to use this stepper motor for all axis.
  #2
Old Tue 30 November 2010, 06:14
A CNC router requires a high-torque motor. Unfortunately, you cannot drive a large machine with a low-torque motor. The single-chip stepper controllers are not meant to be used on a CNC machine; they are more often found in a floppy disk drive or other constant step-rate application. You will need a size-34 motor that produces at least 300 oz*in (if you use a belt-drive transmission) or around 600 oz*in if you use direct drive. The Geckodrive G20x series of stepper drivers (or equivalent) would be the proper type of stepper drivers for a CNC machine.
  #3
Old Tue 30 November 2010, 11:55
For build it yourself ideas you could see www.pminmo.com. There are some designs available there that might do the job. The Gecko drives Mike mentioned also work very well.
  #4
Old Tue 30 November 2010, 12:09
Do we really want to discuss such a small $18 motor on this forum?
  #5
Old Tue 30 November 2010, 16:30
EricW
Just call me: Eric
WI
Nope.
  #6
Old Tue 30 November 2010, 16:45
Well, if we eliminated the v-rails and v-wheels, doubled the racks with one on top and one below, and placed two motors everywhere there used to be a wheel, then got all 28 little motors running in sync ...
... Yeah, I guess we don't have much use for the little motors
  #7
Old Tue 30 November 2010, 16:54
Agreed
Closed Thread
UIROBOT Stepper Drives uirobot The Market Place 76 Tue 31 January 2012 09:45
Universal Stepper Controller Ticapix 701. Motor Drives 1 Tue 25 August 2009 20:41
True Torque of a Servo motor for comparison to a Stepper motor, when used in a router Mcyoda Motors & their mountings 3 Tue 19 August 2008 00:50
K4- Bipolar Stepper Controller Board javeria The Market Place 0 Tue 29 January 2008 18:26
The SuperTech GeckoPwr IV Electronic Micro Step Motor Controller Gerald_D 70. Control Systems 0 Thu 06 July 2006 10:12
