Old Tue 25 August 2009, 15:49
Ticapix
Just call me: Thierry
Toulon
France
Universal Stepper Controller
Hi from France,
Who know this card http://www.pico-systems.com/univstep.html ?
Now we have driver like G203 which make µsteps up to 1/256 or more, input pulse up 300 khz, but our BOB is limited at 15/20khz in the best case.
On the most of our MechMate
We can found: stepper gearedmotor 1/3.6 - 35 teeths (109.96 mm per turn) - µsteps 1/10 - resolution 0.015 mm - one turn = 7200 pulses ( 7.2 khz)
With universal stepper controller, we can use 1/32 µsteps/resolution = 0.0043
=> one turn / s need 23 040 pulses => impossible with normal computer
Displacement on the X axis, high speed for example 300 mm/s need 2.73 turns pinion and 62 899 pulses or frequency of 62 khz.
All this seems possible with this card ? Magic or truth ? easy to install ?
What is your opinion ?
Thierry
Old Tue 25 August 2009, 20:41
Thierry, there are a couple of cards which will generate the steps outside of your PC. Most people use the SmoothStepper because it is supported by the Mach3 software. (The Pico UnivStep runs with EMC2 software).
In France you also have http://www.techlf.com/ with some controllers. I am sure that there are many more.
Mixing different drives on the same controller shelbygt500buddy 701. Motor Drives 5 Mon 15 June 2009 21:55
CAD files for controller components? cncb General - MM Build 4 Tue 12 May 2009 09:02
Plasma torch height controller agelkom The Market Place 0 Wed 15 April 2009 11:27
K4- Bipolar Stepper Controller Board javeria The Market Place 0 Tue 29 January 2008 18:26
Anyone have a MechMate controller fully documented? cncb 70. Control Systems 23 Fri 04 January 2008 03:43
