Old Thu 26 November 2015, 14:45
gixi
Bucharest
Romania
CNC USB Controller
Hello to everybody !
Two days ago a friend of mine build a small 4 axis machine driven by CNC USB.
This small machine is very precise, the settings of the software are quite intuitive and the most important it works with USB connection.
With this machine he shapes carbide inserts for router bits something like this http://www.amanatool.com/products/cn...3-4-shank.html.
So its easy to imagine that the margin error is very small.
Could this be the replacement of Mach3/Mach4 ?
Old Fri 27 November 2015, 05:01
Do you have the name of this USB controller and software?
Old Fri 27 November 2015, 05:29
ger21
Just call me: Ger
Detroit, MI
As Mike said, which specific control are you talking about?
There are a several alternatives to Mach3 and Mach4.
These four are probably the most comparable ones:
UCCNC
EdingCNC
LinuxCNC
Planet CNC
You can probably also add Flashcut in there too. While it's much more expensive, the price is somewhat comparable to a Mach3/Mach4 setup with a high end motion controller like a Hicon or CS Labs.
There are also several low cost options used on small hobby machines like the ShapeOKO and X Carve type machines.
These tend to be lacking in features, and in some cases use a web based front end.
I think there are at least one or two more controls sold in europe that I'm not familiar with.
Old Fri 27 November 2015, 09:42
gixi
Bucharest
Romania
This is the link to their site :http://www.planet-cnc.com/index.php?page=home
They have the hardware and the software.
Old Fri 22 January 2016, 06:23
brazgotine
Just call me: brazgotine
Ljubljana
Slovenia
I use their sw/hw solution and i can tell you that it is definitely one of the most simple softwares out there.
You can get so much done in so little time.
Board itself is very quality made.
Old Wed 27 January 2021, 12:16
Jiomneller7
Just call me: Jiom
New york
As mentioned i am continuing my same topic thread in this old thread. So i am also looking for USB CNC Controller. From one source of information i got to know about GOWE 3Axis Offline Controller, it supports the FANUC with high universality to be compatible with the G code set. Moreover, the port of this controller is expandable.
Looks a good one but open to know more suggestions.
Old Mon 15 February 2021, 10:43
sifongreyshark
Just call me: greyshark
Kyiv
Ukraine
https://newker-cnc.en.alibaba.com/
UC100 Motion Controller Surfcnc 80. Computer Hardware & Software 24 Mon 20 January 2014 00:17
For Sale New PMDX-132 Controller BOB Don_Kellogg The Market Place 1 Tue 15 February 2011 07:39
Selecting Stepper motor controller IC same79 Archives 6 Tue 30 November 2010 16:54
Universal Stepper Controller Ticapix 701. Motor Drives 1 Tue 25 August 2009 20:41
Mixing different drives on the same controller shelbygt500buddy 701. Motor Drives 5 Mon 15 June 2009 21:55
