Old Mon 30 January 2023, 00:24
AccTekcncLaser
Just call me: AccTekcnc
Jinan
China
Diffusion of domestic laser cutting machines and advantages of laser processing
The laser processing technology of optical fiber laser cutting machine has the following unique advantages:
Using laser cutting machine for laser processing can effectively improve production efficiency, improve economic efficiency and ensure product quality.The medium can improve the cutting efficiency and cutting range, and can handle various workpieces in a closed container. Laser processing can be carried out even in harsh environments.
https://www.acctekgroup.com/uploads/...2105111PZ1.jpg
Laser processing can eliminate tool wear, module limitations, etc., thereby reducing costs.It can process various metals and nonmetals, especially materials with high hardness, high ductility and high melting point.
The laser beam is easy to guide and focus, and can realize the conversion compatible with the digital control system, which is a very flexible processing method.
In the case of non-contact processing, it has no direct impact on the workpiece, and can adjust the energy of high-energy laser beam and its moving speed without changing the machine, and realize various processing applications.
In laser processing, the laser beam has high energy density, and local processing can maintain high speed, and the heat affected area is small, which can reduce the thermal deformation of the workpiece, and can avoid the subsequent complex processing needs.Low cost compact solution using semiconductor optical fiber as laser generation medium.
Tolerance of laser cutting sh.y1234 Profiled (laser cut) & bent steel plate 6 Mon 25 April 2011 12:21
Laser Parts cutting with cnc router asif3244 Profiled (laser cut) & bent steel plate 4 Wed 01 December 2010 10:36
Laser Cutting Parts lisawaa The Market Place 6 Tue 14 September 2010 13:07
Laser/Water cutting racks? PEU Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 2 Sat 21 March 2009 10:54
Laser cutting in various countries . . . . vadeem Archives 12 Thu 02 October 2008 08:02
