Go Back   MechMate CNC Router Forum > Common Assemblies & Parts > Profiled (laser cut) & bent steel plate
Old Tue 30 November 2010, 03:05
asif3244
Just call me: Asif
Abu Dhabi
United Arab Emirates
Laser Parts cutting with cnc router
Hi
Dear Gerald_D i am member since a year but was only learning, now i plan to get started, i am a Pakistani working in Abu Dhabi U A E, i will start to build in Pakistan, as import is a difficult process in Pakistan, importing in U A E is easier due to free port facilities, Laser cutting is available here in U A E but i have tried cutting with cnc router that our company import from china, i am gathering the parts at this time soon will start to build
Old Tue 30 November 2010, 03:35
asif3244
Just call me: Asif
Abu Dhabi
Hi
here is the metal cutting video
http://www.metacafe.com/w/5575371
http://www.metacafe.com/watch/557537...th_cnc_router/
Old Tue 30 November 2010, 13:49
Is that 1/4 or 6mm steel? How fast is that router turning?
Old Tue 30 November 2010, 18:52
rayditutto
Just call me: Robin
Victoria
Send a message via MSN to rayditutto
according to the video comment, "3mm old steel with 4mm carbide bit"
seems to produce a slurry (for lack of a better word) rather than chips
i'm curious also about the feed rate and type of bit (straight, spiral etc)
Old Wed 01 December 2010, 09:36
asif3244
Just call me: Asif
Abu Dhabi
Hi
Robin, The steel is 3mm tool is 4mm carbide G-code made in art-cam steel tool
Feed rate 60 to 180 mm/min depends on type of tool, plunge rate 50 mm/min
V F D controlled speed should be adjusted to an normal hand drill tool
MechMate Laser Kit Parts in the US ddoggett The Market Place 62 Wed 24 August 2016 10:12
Laser Cutting Parts lisawaa The Market Place 6 Tue 14 September 2010 12:07
Surplus Laser Parts rotorzoomer The Market Place 0 Fri 25 June 2010 07:32
Laser cut and formed parts Castone Profiled (laser cut) & bent steel plate 5 Sat 05 September 2009 00:40
Source for laser cut parts Medemt General - MM Build 1 Sun 29 March 2009 18:08
