| Welcome to the MechMate CNC Router Forum. |
| If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below. |
| Forum | Last Post | Threads | Posts | ||||
162 | 2,615 | |||||
27 | 613 | |||||
261 | 1,841 | |||||
Personal Build Histories
A place where individuals can start and "own" a thread about their personal experiences and endeavors. Feel free to start your own support group in your location.
Tell us who and where you are, your skill levels and the future application of your MechMate.
502 | 4,462 | |||||
Start your own build history in this thread. Photos are appreciated.
166 | 4,885 | |||||
Personal threads will be moved here once a machine moves and cuts under command. Serial#'s will be given to machines that are neatly finished (painted, preferably MM blue if you don't want to be teased ;-)) and have the MM logo applied.
200 | 28,560 | |||||
Structure & Mechanics
The big non-moving part. Also how indexers are mounted.
95 | 1,241 | |||||
Rides on the main beams of the table, moves in x-direction
35 | 409 | |||||
Rides on gantry, moves in y-direction, carries the z-axis.
11 | 92 | |||||
Plunges tool in z-direction
47 | 609 | |||||
The mounting of routers, spindles, plasma cutters, engravers, drill, pencils, etc.
120 | 1,831 | |||||
Dus collection feet, skirts, height setting, hoses, cyclones, gates, blowers, filters, anti-static, anti-fire, electrical control, etc.
47 | 585 | |||||
Common Assemblies & Parts
Mechanical parts and assemblies common to more than one of the above components
| 31 | 652 | ||||||
| 104 | 1,561 | ||||||
| 81 | 1,365 | ||||||
| 63 | 1,504 | ||||||
Electrical & Electronic
Selecting the right types and sizes of cables & wires. Managing the bundles of moving cable. Cable chains. Good wiring practice.
41 | 795 | |||||
Typically the wall-mounted box that accepts mains power, transmits control signals between the PC and the table, and drives all motors to correct positions and speeds.
157 | 2,493 | |||||
High current electronic devices that control the position and speed of electrical motors. For steppers, servos and spindles. Includes Geckodrives.
81 | 873 | |||||
The devices which convert incoming mains AC to the correct DC voltage and capacity for powering the 701. Drives of the steppers or servos. Part of the Control System.
75 | 1,060 | |||||
Computing, Software & Programming
Generate control signals fed to the Control Box
41 | 526 | |||||
These types of software typically give an output in .dxf format
50 | 467 | |||||
These types of software typically accept .dxf and give an output in g-code format
32 | 262 | |||||
These types of software typically accept g-code and give electrical output signals
39 | 489 | |||||
| 26 | 263 | ||||||
After Building the Beast - Operating , Troubleshooting and Maintenance
General methods and techniques for doing CNC routing work
39 | 483 | |||||
| 45 | 513 | ||||||
| 109 | 1,781 | ||||||
| 5 | 56 | ||||||
After you have shown us pictures of your MechMate, please show us some of the stuff you made with it.
107 | 973 | |||||
Miscellaneous hardware and software
The positioning and housing of keyboards, monitors, pushbuttons, etc.
10 | 140 | |||||
Anything not directly connected to constructing a MechMate CNC table system
206 | 2,564 | |||||
| 32 | 314 | ||||||
Please bounce this thing around . . . . . .
25 | 197 | |||||
This is a paid area. Please goto USER CP in the upper left hand corner of the screen and scroll down to paid subscritions to access the items you want.
2 | 2 | |||||
19 | 129 | |||||
234 | 3,250 | |||||
| What's Going On? | |
MechMate CNC Router Forum Statistics
Threads: 3,390,
Members: 38,382
Welcome to our newest member, Kirsi
