Old Wed 17 February 2021, 12:48
paul60
Just call me: woodguy
st george
Barbados
Zero touch place not connecting
I am running mach3 BOB PMDX-122 Gecko drive G203v.
been running for a few years with no problems.
just had a problem popped up i went to zero to the table top using the zero plate
when i ran the zero. The spindle moved down but did not stop when it touch the plate. have to hit the page up for it to go back up.
been using a piece of paper to zero.
any idea where to start looking to correct this?
Paul
Old Fri 19 February 2021, 08:58
Kenrbass
Richmond Tx
On the last page of the mach screen you can view the inputs. Touch the plate to a good ground while watchine the inputs. Sometimes older routers don't ground through them after lots of running. If the input works as shown on the screen, I would suspect the router is not passing ground. You can replace the router or use a ground wire clip on the bit if that is the case.
Old Fri 19 February 2021, 10:47
paul60
st george
Barbados
Thanks Kenrbass
Found it it was a broken connection on the z zero plate lead
Basics of connecting E-stop Contactor & (Door) Isolator switch lunaj76 70. Control Systems 35 Sat 30 June 2012 10:02
Power supply kl-6520 - connecting it in Europe? kongblom 702. Power Supplies 4 Sat 17 October 2009 02:04
The new "Market Place" - vendors invited to set up shop Gerald D The Market Place 1 Sat 04 April 2009 04:34
Connecting Shielded Cable to motors KevinL 60. Wiring & Cable Management 4 Thu 15 January 2009 06:45
MM Mamba-Drawing Index and Option Schedule documented in one place Abdul Archives 0 Sat 24 November 2007 09:44
