Old Fri 16 October 2009, 15:16
kongblom
Just call me: Nikolaj
Copenhagen
Denmark
Power supply kl-6520 - connecting it in Europe?
hey all..
I have a small problem with a power supply I bought from
www.kelinginc.net (kl-6520 power supply)
the problem is that I can not figure out how to connect it to the electricity grid in my workshop, there are 4 wires: 2 black and 2 red . since I live in Denmark (Northern Europe) we use 220 and 400 volts so I assume that I need the setup for 220 VAC, it says
1st red wire to neutral, 1st black wire to 2nd red wire, and the 2nd black wire to hot.
here comes the problem:
the outlet for 220 volts in Denmark has 3 legs, 1 ground and 2 phase
However, the 400 volt has 3 phase and ground.
or 2 phase 1 zero and 1 ground .
I'm really not a Electricity genius because I cabinetmakers
are there some who can help me, if it makes sense
what I write...!
Old Fri 16 October 2009, 15:36
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
European 220v power has phase on one leg second is neutral and third is grounding. You can take power from 400V socket too, it has voltage between phases 400v and voltage between one phase and neutral 220V.
Old Fri 16 October 2009, 16:10
kongblom
Copenhagen
Denmark
ok.. 1 red and 1 black wire goes to ground and the 2 others goes to neutral and phase. is that accurate.?
Old Fri 16 October 2009, 21:10
That is not correct
The transformer must not be connected to ground
You only use neutral and phase:
phase to 1st red wire, 1st black wire to 2nd red wire, and the 2nd black wire to neutral.
The case of the power supply is connected to ground.
Old Sat 17 October 2009, 02:04
kongblom
Copenhagen
Denmark
ok thanks..
was a little confusing with the 2 wires be put together..
Why not use an adjustable, regulated power supply? Bob Cole 702. Power Supplies 19 Thu 25 August 2011 09:33
Troubleshooting a DIY Power Supply shelbygt500buddy 702. Power Supplies 17 Wed 16 September 2009 20:11
power supply 30VAC 300VA guri 702. Power Supplies 13 Fri 19 June 2009 12:41
