Thread Tools |
Stepper Motor - Controller & Driver all in one!?
Hey All,
Am in the process of making the big decision when I stumbled across these motors! More so out of curiosity but is a motor like this, or something similar appropriate for the MechMate? http://www.orientalmotor.com/product...r.html#content Thanks |
These motors are 5 phase motors and the Mechmates usually use either 2 or 4 phase motors.
The smaller step angle of the 5 phase motors makes for a smoother motor and can result in more usable torgue than an equivalent size two phase motor. The down side is that the low voltage signal wires will need long runs to make it to the drive and may be more prone to signal interference unless adequate shielding has been incorporated. In summary their is no reason why a correctly sized motor/ drive combination would not work. They would probably be more expensive than a standard 2/4 phase motor. Ross |
I checked further into the Oriental Motor product line up and there are no motors large enough to run the Mechmate.
These motors are tiny, the BIG one is 0.83 Nm and you will be needing around 4 Nm. Best to read http://www.mechmate.com/forums/showthread.php?t=1114 to get a idea of the size and types of motors commonly used before looking further afield. Ross |
Oriental Motor has the RK596AAE motor/driver for those who want an AC powered stepper driver. That motor is rated at 290 oz*in and holds its torque very well to 600 RPM. With a 4:1 beltdrive it would jog at 9.8" per second with the motor spinning at 600 RPM. A 4:1 gear ratio would give you about 1,160 oz*in of torque. Of course, with proper ramping, the motor could jog faster than that. The price is $586, which is almost 2X more expensive than a PK296-F4.5 motor and a G201x stepper driver.
A larger RK599AAE sells for $652.80. Both motors have controllers that have adjustable step angles. Personally, I prefer to use Geckodriver stepper drivers with Oriental Motor stepper motors. They are inexpensive and reliable. But, for those who want to buy parts from a single supplier, it is something to consider. |
| Stepper Motor, Driver and Power supply - Kelling | Kelinginc | The Market Place | 2 | Sun 03 April 2011 01:24 |
| Selecting Stepper motor controller IC | same79 | Archives | 6 | Tue 30 November 2010 17:54 |
| TIP142 Stepper motor driver | musicworld1 | 70. Control Systems | 19 | Tue 28 September 2010 22:23 |
| Would you mind to help me to solve the problem for Keling stepper Motor Driver? | qangel1000 | Motors & their mountings | 6 | Sat 08 August 2009 00:42 |
| Keling Stepper, Servo Motor and Driver | Kelinginc | The Market Place | 0 | Wed 16 January 2008 14:55 |
