Old Sun 15 April 2012, 03:22
What are those "lumps" on the wash line pole?
Old Sun 15 April 2012, 04:54
clarson66
Just call me: Chris & Leon #100
Adelaide
Yeah she didn't find it funny when I asked her to get all the washing off so Icould hang some stuff up. But on the plus side our MM is finally getting ready to go BLUE!
PS Gerald if you are referring the silver lump above the handle winder it's a peg bucket the old guy that owned the house before made up
Old Sun 15 April 2012, 08:07
We don't even have the handle winders here.
Old Sun 15 April 2012, 21:13
Jayson
Just call me: Jayson #18
Horsham
Here in Australia we have so many people from all over the world living happily together, what this means is we have women folk of many varying heights, so Mr Hills designed the Hills Hoist to allow the height to be changed so that they could get the clothes line to the correct working height and joyfully hang out the washing. This results in our women being wonderfully happy and welcome us with open arms when we get home every night...
Its also handy to raise things up a little when painting.
Old Wed 18 April 2012, 06:11
clarson66
Adelaide
Z Plate finally happening
We have managed to get a good price on the plate for the Z axis, found a dealer in Melbourne who was overstocked and happy to sell us a piece delivered for less than any of my quotes from Adelaide. Also thanks to a friend who races cars we now have his machinist to machine the plate up for us. Just need for finish the paint job and it will soon be time to start final assemble.
Chris
Old Sun 22 April 2012, 05:09
clarson66
Adelaide
Mechmate in a booth!
Well another day on the MM build. Today was the last day of cleaning up the last bits of surface rust, she has been sand blasted, rainex rust converted, wire brushed and sanded. Then wheeled it into the temp spray booth I made and let the primer fly. Interesting thing to paint so many angles and sides, seemed like every time I moved there was another bit I'd missed. Well finally got it all primed, u can see it in there somewhere.
Chris
Old Wed 02 May 2012, 03:36
clarson66
Adelaide
Z Plate is done
Phone call from the machine shop and a quick drive down to his workshop and we now have our Z-plate. Just need some time of work and we can get the spider finished.
Old Thu 17 May 2012, 00:22
clarson66
Adelaide
X rails set up
Hi all, just looking for some feedback. I was setting up the x rails the other day and its seems despite all our care and measuring and previous rough trial set ups, that some how we have ended up with the tapped holes in the x beams being 6mm overall to close. Meaning I cant get the y carriage to sit down on the v rails.
2 Possible solutions we have thought are
1. Just use 4-5mm of shims on each v bearing
2. Elongate the holes in the rails to slide the rails out further and back to 2 - 2.5 mm of shims.
Any thoughts everbody?
Chris
Old Thu 17 May 2012, 01:14
Regnar
Just call me: Russell #69
Mobile, Alabama
Did you make sure you didnt swap the rails to the other side? What was on the right is now on the left and left is now on the right. A slight offset would be doubled when swapped and could be where you came up short.
Option 1 would be a whole lot easier than elongating a bunch of holes just be sure you have enough on the X axis pinions to come in full contact with the rack.
Old Thu 17 May 2012, 05:05
Quadro
Just call me: Anthony #77
South Australia
I wouldn't recomend enlogating any holes on the x rails. Do you have any 'shims' between the V brg and the Y carrage? It is a bit hard to tell from the photos. Somewhere I read use half of a nut if necessary.
Old Thu 17 May 2012, 09:06
clarson66
Adelaide
We still have 20mm of overhang each side so with the rack being 15mm space shouldn't be a issue. We have tried it in the current holes and can get the y carriage to ride correct with 4mm of shims each side. I was going to look into getting a shim nut if possible. The rails were clearly punched so they are back in the right spot. Im leaning more towards just using the 4mm shims or a nut, was just concerned cause I have seen it mentioned about 2.5mm of shims should be all you need. But that is a lot of holes to elongate.
Chris
Old Thu 17 May 2012, 10:21
4mm of shims, or a standard heavy washer + shims, should be quite acceptable
Old Thu 17 May 2012, 19:32
clarson66
Adelaide
Thanks Gerald,
I Was thinking it should be right but its always nice to get advice from experienced folk. 4mm washer and shim to true it up it is, back in the shed on the weekend and I will get it rolling again.
Chris
Old Sun 20 May 2012, 06:36
clarson66
Adelaide
Its Rolling
Well we finally made it out to the shed, lost most of Saturday the wife came back from a holiday and wanted to spend time with me.
After sorting the shims for the Y carriage bearings, I got the X - Rails on and shimmed level. Then Leon came down today and we got the Y carriage on and the rails fitted and shimmed level. It is rolling real nice and smooth. We then decided to start looking at testing the motor mount, which all seemed to go fine as well.
Yes we have decided on a different colour scheme, one of our local auto stores was clearing out 3M paint for $10 a litre and they had Metallic Charcoal - Hammer finish. We thought it would look nice with the black accessories.
Chris n Leon
Old Mon 04 June 2012, 05:47
clarson66
Adelaide
Hi all,
I have been quietly working away on the MM in the background. Sorry I haven't posted any updates but there is good news. Our Mechmate has made the dust fly and is up and cutting, I still need to tidy up some wiring and bits but its definitely cutting. Will post pics and maybe a video as soon as I can get a chance.
Chris
Old Mon 04 June 2012, 21:05
Quadro
South Australia
Can't wait to see the dust!
Old Tue 19 June 2012, 06:50
clarson66
Adelaide
Running and stickered!
Hi all,
Been playing around with the MM making lotsa dust. Purchased a up/down compression cutter, cut melamine board real nice. Been doing a bit of engraving and just mucking around. Have purchaed some acrylic to play with and have orded some strip LED lights for making some signs for fun. Thought I best do the square test and check the machine, had just under 1mm difference on the diagonals and after a quick adjustment and some changing of shims it all squared and ready to go.
Have put the stickers on and now await to see if we have earned the honor of a serial number and which one 98, 99 and who's is goin to get the 100th?
Oh yeah and the last photo is something from one of my muck around sessions.
Old Tue 19 June 2012, 07:34
Great job!
If you want #100 you need to ask Mike if he will reserve it for you
Old Tue 19 June 2012, 07:44
Great job, Chris and Leon.
I'm in the running for #100.
Old Tue 19 June 2012, 07:46
clarson66
Adelaide
Would be nice to have the #100 I will leave it up to Mike to make the decision of who will have that honor (Hi Mike). After 2 years in the making I am just happy and excited to see it finally cutting.
Old Tue 19 June 2012, 07:49
clarson66
Adelaide
Congrats 2 Darren, I have been watching ever ones posts as well thinking who is going to get the #100.
Old Tue 19 June 2012, 08:29
And we have this machine in the running for a number as well . . .
Old Tue 19 June 2012, 09:38
Quadro
South Australia
Well done Chris!
I was 'holding back' on the second machine so I could swipe #100.
Old Wed 20 June 2012, 00:32
clarson66
Adelaide
Yes I was wondering how many people were holding of before posting they were done, as I said b4 I'm just happy to have it running. Although if I am not mistaken do we not have 3 Aussie builds in the running for the #100?
Old Wed 20 June 2012, 03:21
I reckon that 99 is more "sexy" than 100.
In a flash I can can produce photos of 4 unlisted machines, stickered and cutting, and grab the next 4 numbers , but I won't do that .
Old Wed 20 June 2012, 05:45
clarson66
Adelaide
I was thinking the same Gerald, #99 does sound nice I would be happy with that.
Old Wed 20 June 2012, 07:29
I hope you all realized I was tongue-in-cheek about the serial #.
Whatever number I end up with will be fine with me.
A 100series machine sounds just as sexy to me....
I just want a running machine like the 100+ before me already have.....
Old Wed 20 June 2012, 07:36
Gerald, are you holding out for #111,#333,#777, and #999?
Old Wed 20 June 2012, 08:22
Brad, holding out for the mark of the Blue Beast #666
Old Fri 22 June 2012, 06:32
Now that #99 has been allocated, this must surely be #100? The photos in post #77 are the qualifiers.
Looking for Steel - Adelaide, AU Sinbad Introduce yourself and start planning 21 Wed 11 November 2015 22:22
New Vacuum Table! #67 - Littleton, NC salewis MechMates already cutting 137 Sat 13 October 2012 05:54
Vacuum Table.... salewis 10. Base Table 5 Mon 08 August 2011 22:23
Finished writing plugin for Mach3 to control the VFD via RS-485 - Adelaide, Australia MattyZee MechMates already cutting 99 Sun 06 March 2011 05:05
vacuum table question tldj55 General - MM Build 1 Sun 23 January 2011 20:53
