Old Sun 07 August 2011, 17:57
salewis
Just call me: Stan #67
Littleton, NC
Vacuum Table....
Ok ladies and gentlemen, with about a year (little less) of use on our MM it appears that most of our work would be made much easier through a vacuum table.
I have read through several blogs and even visited other (*&^%bot) sites.
We have a 5x10 table and are considering two LH brand motors from central vacuum motors. We are thinking of laying another 0.75 inch of MDF to the existing 1.00 (little less due to surfacing) and cutting the vacuum plenum in that with a 0.50 router bit (cutting 0.50 deep) and then using additional MDF for the spoilboard.
The questions are simple. Do we need to plan for running these motors in both parallel and series? Also the knife valves, do they need to be metal blades or will plastic work?
Also references to machines with plenum pics would be grateful.
Stan
Old Sun 07 August 2011, 23:45
Stan,
Surely you can set up for swapping between series, parallel or individual for your own amusement, I choose to set up in parallel & a single port, this works great on 90% of what I do.
The trick is in managing your leakage & pay attention to tiny (2"x 4" & smaller) pieces.
My advise is just buy the motors & get on with it.
Have a look at my building thread http://www.mechmate.com/forums/showt...&postcount=418
Old Mon 08 August 2011, 13:02
salewis
Littleton, NC
how many motors are you running (2 or 4)?
Old Mon 08 August 2011, 15:31
[email protected]
Just call me: Adrian
Durban
one motor
Old Mon 08 August 2011, 17:19
salewis
Littleton, NC
geez must be a big one
Seriously, I'm looking at the lighthouse (or is it lighthorse) from centralvacuummotor.com. (120 vac version).
Stan
Old Mon 08 August 2011, 21:23
you should be able to see 2 motors in my pix.
One motor can work too but you can always have as many as you wish.
5' x 10' Vacuum system #60 - Pembroke, Ont WFY MechMates already cutting 51 Fri 01 April 2011 03:46
Commercial Vacuum kit silverdog The Market Place 15 Sun 06 March 2011 10:03
vacuum table question tldj55 General - MM Build 1 Sun 23 January 2011 19:53
Vacuum Crane sailfl Miscellaneous / General / Whatever / Catchall 0 Fri 13 February 2009 20:12
