Old Tue 02 August 2011, 06:32
I have placed this tread out of the general build area as it appears this device will not be following the standard. I will be keeping an eye on the thread to see how it may benifit the MechMate group going forward.
Have fun with your build and if you do decide on the MechMate design, I will place your thread back over in the build area.
Old Tue 02 August 2011, 08:20
Vern2
Just call me: Vern
Gilbert, Arizona
MetalHead,
It all comes down to the money, I'm basically removed.
Vern
Direct motors 4Nm and 6,8Nm tomasptacek Motors & their mountings 0 Wed 26 May 2010 02:25
Newbie needs help with figuring out drive configurations (slaved drive for x-axis) ikeike 701. Motor Drives 5 Mon 04 January 2010 21:06
Slaving a motor - put its drive in parallel to another drive on the same BOB output J.R. Hatcher 70. Control Systems 34 Mon 16 November 2009 09:13
Automation Direct power supply . . . or a Switch Mode MeanWell bfauska 702. Power Supplies 14 Tue 11 August 2009 10:16
MechMate in Arizona Kevin Construction started, but not cutting yet 7 Sat 22 December 2007 10:52
