Thread Tools |
UIM 240xx step driver help.
Hi;
I'm sorry if I wrote the wrong topic section. problem with a link, http://www.mechmate.com/forums/showthread.php?t=2687 pdf files UIM240 model, the driver, I can not run with Mach3. I connected the LED pins on the XYZ axes running. Step pin: yes, okay - dir pin: yes, okay How where you need to connect the Vcc pin.? please help me. |
What type of BOB are you using ?
Thanks for the help. I also looked at the photo (UIM240-pdf). you say your shape exactly. I asked, but, whichever LPT pin. or together to make another circuit. |
The pin from parallel port depends on your TYPE of BOB and where you pick up the connection
(The pin from parallel port depends on your TYPE of BOB and where you pick up the connection)
I'm sorry could not make gogle translation. I could not understand. My connection is like that. |
BOB = Break out board.
You still need to tell us which 'Break-out Board (BOB)' you are using WITH your stepper drivers (UIM240). You need a BOB to send the signals to the drives (UIM240).
#10
window_s,
Break-out Board = 25 pin Interface board. What type of board did you use? |
#11
This will be a difficult one
#12
Actually, IMHO, any 25pin parallel port BOB will do... You can even run without one...
I recon Window_s has a language problem more then anything else. Give him/her some time... |
#13
Would like to thank all the friends who helped me. No problem now. I find the cure. Solution of the problem is in the picture. |
#14
to be very easy.
![]() ULN2003 great device ![]() |
| my first step , v rails | oscaryrc | Introduce yourself and start planning | 5 | Thu 12 August 2010 00:19 |
| Slight step over on second/third pass | Dan Sj0 | Troubleshooting | 2 | Sat 10 July 2010 06:55 |
| STEP 1 - Introduce myself, FFEJ from Geelong | ffej | Introduce yourself and start planning | 8 | Fri 22 January 2010 02:20 |
| Mounted X-rack's with different heights - causes step at joint. | Barman | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 10 | Tue 17 March 2009 08:03 |
