Old Sat 24 July 2010, 15:51
oscaryrc
Just call me: oscaryrc
az
my first step , v rails
my first cnc router , v rail construction
Old Sat 24 July 2010, 19:16
Welcome Oscar!
Those rails look a little high for the MM design. You will need to cut them to the right height before doing the 45 degree bevels.
Old Sun 25 July 2010, 07:37
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
Welcome Oscar
As Heath said you will need to cut the height before doing the 45 degree, but you may also want to get the rails fitted and drilled for mounting on the main longitudinal beam. After I cut my rail to size it bowed and had to be affixed to the main longitudinal beam for grinding. You should follow the plans layout as it is a step by step process.
Old Wed 11 August 2010, 22:27
oscaryrc
az
cnc router 30x30
ready to cut
Old Wed 11 August 2010, 22:55
oscaryrc
az
waterjet parts
next week cuts parts mechmate , i have motors, rails v, bearings
Old Wed 11 August 2010, 23:19
Ready to sell!
Slight step over on second/third pass Dan Sj0 Troubleshooting 2 Sat 10 July 2010 05:55
STEP 1 - Introduce myself, FFEJ from Geelong ffej Introduce yourself and start planning 8 Fri 22 January 2010 01:20
Mounted X-rack's with different heights - causes step at joint. Barman Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 10 Tue 17 March 2009 07:03
Using the Oriental Motor Alpha-Step motors on the MechMate frames. Gerald D Archives 1 Sat 29 September 2007 11:43
The SuperTech GeckoPwr IV Electronic Micro Step Motor Controller Gerald_D 70. Control Systems 0 Thu 06 July 2006 10:12
