Old Sat 30 July 2011, 11:22
window_s
Just call me: window_s
ist
Turkey
UIM 240xx step driver help.
Hi;
I'm sorry if I wrote the wrong topic section.
problem with a link,
http://www.mechmate.com/forums/showthread.php?t=2687
pdf files
UIM240 model, the driver, I can not run with Mach3.
I connected the LED pins on the XYZ axes running.
Step pin: yes, okay - dir pin: yes, okay
How where you need to connect the Vcc pin.?
please help me.
Old Sat 30 July 2011, 12:16
What type of BOB are you using ?
Old Sat 30 July 2011, 12:24
Old Sun 31 July 2011, 08:13
window_s
ist
Turkey
Originally Posted by Kobus_Joubert View Post
Dear @kobus Joubert
Thanks for the help.
I also looked at the photo (UIM240-pdf). you say your shape exactly.
I asked, but, whichever LPT pin.
or together to make another circuit.
Old Sun 31 July 2011, 08:22
The pin from parallel port depends on your TYPE of BOB and where you pick up the connection
Old Sun 31 July 2011, 08:44
window_s
ist
Turkey
(The pin from parallel port depends on your TYPE of BOB and where you pick up the connection)
I'm sorry could not make gogle translation. I could not understand.
My connection is like that.
Old Sun 31 July 2011, 11:23
timberlinemd
Just call me: Steve #66
Arizona
BOB = Break out board.
Old Sun 31 July 2011, 12:09
window_s
ist
Turkey
Video
youtube
Other pages CNC Zone site
thanks
Old Sun 31 July 2011, 22:14
timberlinemd
Arizona
You still need to tell us which 'Break-out Board (BOB)' you are using WITH your stepper drivers (UIM240). You need a BOB to send the signals to the drives (UIM240).
Old Mon 01 August 2011, 00:18
window_s,
Break-out Board = 25 pin Interface board.
What type of board did you use?
Old Mon 01 August 2011, 00:22
This will be a difficult one
Old Mon 01 August 2011, 00:50
Actually, IMHO, any 25pin parallel port BOB will do... You can even run without one...
I recon Window_s has a language problem more then anything else. Give him/her some time...
Old Mon 01 August 2011, 06:08
window_s
ist
Turkey
Would like to thank all the friends who helped me.
No problem now. I find the cure.
Solution of the problem is in the picture.
Old Mon 01 August 2011, 06:17
window_s
ist
Turkey
to be very easy.
ULN2003 great device
my first step , v rails oscaryrc Introduce yourself and start planning 5 Thu 12 August 2010 00:19
Slight step over on second/third pass Dan Sj0 Troubleshooting 2 Sat 10 July 2010 06:55
STEP 1 - Introduce myself, FFEJ from Geelong ffej Introduce yourself and start planning 8 Fri 22 January 2010 02:20
Mounted X-rack's with different heights - causes step at joint. Barman Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 10 Tue 17 March 2009 08:03
