Old Wed 15 June 2011, 20:03
Builder's Log Update
Greetings Vanja,
Congratulations on your new MechMate and on earning Serial #84.
Please review your entry and let me know any changes you want to make.
Old Thu 16 June 2011, 02:31
vanja.ivancic
Just call me: vanja #84
mortara
Italy
Thanks all !!!!
Sorry for the worst built time I've done.
Old Thu 16 June 2011, 04:15
vanja.ivancic
mortara
Italy
Center finding works like Danilo said. I have changed feed rate ( 100 insteed of 4)
Old Thu 16 June 2011, 09:15
Congratulations Vanja!
Old Sat 18 June 2011, 06:07
Vanja,
The Update to the Builder's Log that you requested is complete, here.
Thank you for providing the update. I made the change at the airport while on vacation and it didn't work properly. I'm sorry for the delay.
Congratulations again on completing you MechMate!
Old Mon 04 July 2011, 04:26
vanja.ivancic
mortara
Italy
Last work I've done was a landscape for archittectural modeling.Time of milling was 5 hours. I was afraid what to do if I must stop the machine in the midle of the work, How to find a zero position and countinue.I have put two cuper plates on the angle of base table to find a zero position (mach blue screens).
Whatever hapens I can find the same zero position in this way and continue
using "run from here" mach3- option.If I start to work in the center of the base table I can Write the DRO coordinates x and y to be shure that my zero point is the same.Am I wrong?
Some photos
[ATTACH]angolo flesh.jpg[/ATTACH]
Old Mon 04 July 2011, 05:53
kaartman
Just call me: Koning #20
Abu Dhabi
United Arab Emirates
Hi Vanja, that is a much needed addaption the Mechmate, your understanding is correct about the offset and the zero finding, i have also added the x/y probing to my mechmate, on long carving time projects i also put a V bit into the collect and mark the X and Y positions on the outer parimeter of the material, i guess I will do that untill i am more knowledgeable about what i am doing.
Starting out to actually cut something - cutters, speeds, depths, directions, etc. Richards General - MM Operating 22 Tue 09 July 2013 04:02
Speeds, Feeds, Materials and Bits smreish Cutting various materials - bit selection, feeds, speeds 65 Sun 11 March 2012 09:01
hello from Italy (Naples) federicodimeo Introduce yourself and start planning 1 Mon 25 October 2010 12:24
Hello to all from Italy Biribago Introduce yourself and start planning 2 Tue 06 April 2010 22:58
Ciao from Italy ! silverdog Introduce yourself and start planning 15 Thu 04 June 2009 13:37
