Old Sat 11 December 2010, 03:32
silverdog
Just call me: Sergio #70
Rome
Italy
Ciao Stefan,
Compliments for your building !
As you see I just completed the my Mechmate .... so I'm fresh on spindle buy.
I bought a 220 V - 2,0 kw. The choise between 220-380 it just relatet on what you have as line in your shop, the advantage of 380 V is that you charge less your supply line (3 wire (+1) inster of one) but concerning the spindle there is no difference (the spindle is always 3 phase 220 or 380 but both 3 phase). About the power I was considering a 3 kw but a friend told me that he has a 2 kw wich is perfect, so for an economic reason :-) I choosed a 2kw .... well it was a good choice it's very powerfull. no need for more power. Somewere Gerald said: the power of the spindle is related to the dimension of the mills you need to use. So bigger the mills bigger the spindle. Mine as ER20 collet that means you can use 13mm mills (maniy mills have the shaft of 12 mm but the head is much bigger).
So if you plan to use burs (mills) like those : http://www.youtube.com/watch?v=-HlvA...eature=related
a 2 kw it's not enough, but maybe even the Mechmate it's bit light for those heads mills :-)
or those :-) http://www.youtube.com/watch?v=2mWA7...eature=related
Old Sat 11 December 2010, 07:40
Updated Builder's Log
Stefan,
Great build. Congratulations on earning Serial #73.
Here is the Updated Builder's Log with your entry.
Please review your entry and let me know any changes you want to make.
Old Sun 12 December 2010, 11:40
fanefane
Just call me: Stefan #73
Baia Mare
Romania
Hi John! Thanks for putting me into the list! The final (working) sizes are 2640x1640 mm.
Old Sun 12 December 2010, 18:00
Thanks Stefan,
Update complete, here.
Old Fri 17 December 2010, 09:13
fanefane
Baia Mare
Romania
Some other tests until I'll buy the spindle. I'm still not sure what kind of spindle to buy. http://www.youtube.com/watch?v=0uKL2p5lGEU
Old Sun 19 December 2010, 06:29
fanefane
Baia Mare
Romania
The Winter arrived
It's snowing! It's skating time! How is at yours in the hotter places?
Old Sun 19 December 2010, 08:33
http://www.capetownwebcam.com/live_webcam.htm
Old Sun 19 December 2010, 11:23
That looks just like my yard right now.
Old Mon 20 December 2010, 11:34
fanefane
Baia Mare
Romania
First cutting
And here is the first cutting test! Sorry for the waiting...
I came to refurbish an old spindle which wasn't working and use it for the cutting.
Sorry for the low quality, I couldn't wait any minute longer!
http://www.youtube.com/watch?v=oZEVt_qriUI
Old Mon 20 December 2010, 16:50
Very Cool !!
Old Tue 21 December 2010, 09:00
fanefane
Baia Mare
Romania
And the first sculpting:
http://www.youtube.com/watch?v=LonI_Amkq-k
I don't have the proper milling tools, so the sculptures aren't perfect.
That Bosch spindle has 500W, so I begged to finish the first cutting...
Old Mon 27 December 2010, 06:22
acs
Just call me: Andrei
Campina
Romania
La multi ani ! O treaba extraordinara,felicitari, urmaream subiectul pe rhc. Andrei
Old Mon 27 December 2010, 07:56
Hi Stefan, it is really nice to see the machine hopping from end to end to produce these 3d images.
I would suggest you do the rough cut with a 6mm (1/4 inch is fine ) straight cutter. This reduces time to cut as well. The straight cutter take more wood away than a 6mm ballnose per cut.
Then the final pass you use a 3mm ballnose cutter with a 10% or smaller stepover...you will have a very smooth finish that hardly needs sanding this way.
Softwood will not give a nice smooth cut, but the hardwoods like oak finishes off very nicely.
Old Mon 27 December 2010, 09:25
fanefane
Baia Mare
Romania
Delta
@acs Mersi de urare!
@Kobus Thanks for your tip! I had a 8mm ball mill only so I couldn't do much. I managed to buy an Delta VFD022EL21A inverter at 158E. My spindle hasn't arrived yet... only the next year.
Old Wed 29 December 2010, 10:41
rolix
Just call me: bogdan
Bucharest
Romania
Send a message via Yahoo to rolix
Salut Stefan,
Good job. I prepare myself to start a toy of 3000 x 2000 mm. I hope to come out just look like yours (and at least as good). I still have many unknowns but I'm sure I found the right place to overcome them.
Old Thu 30 December 2010, 06:10
Salut Stefan ???.... Some French in Romania !!! Nice ;0)
I’m no VFD expert by any means, but would too have more “faith” in a Delta than those HuanYang
Good luck !
Robert
Old Thu 13 January 2011, 12:18
fanefane
Baia Mare
Romania
A "lately" Happy New Year to all of you!
I managed to buy a 2.2kw water cooled Spindle and some cutters.
Now the last thing I need to do is to program de VFD. Does anybody have some experience in programming this VFD (Delta VFD022EL21A) with this kind of spindle?
Old Thu 13 January 2011, 14:10
http://www.motorsystems.com/docs/im_...quickstart.pdf
I found this quick start guide... only 25 pages lol !!!
For real though VFD are pretty straight forward if you sit down and read the manual a few times first. You will see things like Minimum Frequency, Accel and Decel Time, Max Freq etc. Max Freq for your unit looks to be 600Hz. Your Spindle is max rated at 400Hz so make sure you don't over drive it.
We do some over driving at the lower freq's like i have done here on my old South Bend Lathe here:
http://www.youtube.com/watch?v=FsR_V..._order&list=UL
Just pay attention to the specs on your spindle and the settings in the VFD. A few times over it and it all starts making sense.
Old Tue 18 January 2011, 13:21
fanefane
Baia Mare
Romania
Thanks for your help Mike!
I managed to program the Delta VFD, it is not so hard as I thought, and the spindle is running very silent (I haven't put the water cooling yet).
Old Thu 20 January 2011, 11:56
fanefane
Baia Mare
Romania
And here we go! http://www.youtube.com/watch?v=qeGTEcGjMBY
I've encountered some difficulties... While taking this on the camera, my clothe was catched and couldn't move. Luckily I took the idea to put more stop buttons and could reach it!
Old Thu 20 January 2011, 12:40
Nice,
What cutter did you use for FINAL cut..
I use 3mm ballnose with 10% stepover.
Another trick is to do final cut in X-direction and then another in Y-direction.
On Youtube I would call it GRAPE not Strawberries ..
Old Fri 21 January 2011, 04:47
Hi Stefan
Thanks for the video, you risked you life to do it for us by the sound of it
All that safety stuff a a complete waste of time and money.... until you need it
The new VFD and spindle looks great on #73.
Old Fri 04 February 2011, 11:06
fanefane
Baia Mare
Romania
And the last test: http://www.youtube.com/watch?v=u9UqwF3Dbww
Took it 10 hours to finish those big grapes...
Thanks and congratulations for this outstanding project, Gerard! The MM handled this work without any problems and it's still standing!
Old Fri 04 February 2011, 12:56
You are brave to do such a big piece. Looking good, but I am sure that you should be able to speed it up a lot more. Once you have done your Rough cut and removed most of the wood with a 6 or 12mm straight cutter, your Final cut with a smaller Ballnose bit should only take about 1mm off, and therefore you can speed it up.
Old Thu 07 July 2011, 14:02
fanefane
Baia Mare
Romania
Hello everybody!
I was a little busy in the past months, but I still managed to do some great stuff with my MM.
http://www.youtube.com/watch?v=0Q-fs...layer_embedded
Old Thu 07 July 2011, 15:33
Sweet !! What are the run times for those?
Old Fri 08 July 2011, 02:26
I like I like Stefan. Is that the mirror from Fabrice ?
Old Fri 08 July 2011, 04:39
fanefane
Baia Mare
Romania
@Mike 10-12 hours, it depends how fast the feed-rate or stepover is.
@Kobus No, I received that model from a friend.
Old Sun 10 July 2011, 02:04
kaartman
Just call me: Koning #20
Abu Dhabi
United Arab Emirates
Very Nice Stefan
Old Sat 16 July 2011, 06:32
fanefane
Baia Mare
Romania
The Last Supper:
Painting in V-Carved (engraved) grooves baseball43v3r Miscellaneous / General / Whatever / Catchall 8 Thu 05 April 2012 04:20
Carved Coat Rack Castone The Show Room 12 Mon 11 January 2010 00:14
3d Elk in walnut with video! Greg J The Show Room 13 Mon 10 August 2009 07:50
3D carved Central ornament javeria The Show Room 10 Mon 03 August 2009 16:50
Engraving text - single line fonts vs. 3D carved Marc Shlaes General - MM Operating 3 Tue 19 February 2008 08:03
