Closed Thread
Old Tue 30 November 2010, 04:23
same79
Just call me: same
fsdf
Selecting Stepper motor controller IC
I am a mechanical engineer and would like to build CNC machine. But for now, I want to know, which stepper motor controller IC I should select. Please help me. I want to use only a simple chip or IC. I want to use this stepper motor for all axis.
Old Tue 30 November 2010, 07:14
A CNC router requires a high-torque motor. Unfortunately, you cannot drive a large machine with a low-torque motor. The single-chip stepper controllers are not meant to be used on a CNC machine; they are more often found in a floppy disk drive or other constant step-rate application. You will need a size-34 motor that produces at least 300 oz*in (if you use a belt-drive transmission) or around 600 oz*in if you use direct drive. The Geckodrive G20x series of stepper drivers (or equivalent) would be the proper type of stepper drivers for a CNC machine.
Old Tue 30 November 2010, 12:55
For build it yourself ideas you could see www.pminmo.com. There are some designs available there that might do the job. The Gecko drives Mike mentioned also work very well.
Old Tue 30 November 2010, 13:09
Do we really want to discuss such a small $18 motor on this forum?
Old Tue 30 November 2010, 17:30
EricW
Just call me: Eric
WI
Nope.
Old Tue 30 November 2010, 17:45
Well, if we eliminated the v-rails and v-wheels, doubled the racks with one on top and one below, and placed two motors everywhere there used to be a wheel, then got all 28 little motors running in sync ...
... Yeah, I guess we don't have much use for the little motors
Old Tue 30 November 2010, 17:54
Agreed
Closed Thread
UIROBOT Stepper Drives uirobot The Market Place 76 Tue 31 January 2012 10:45
Universal Stepper Controller Ticapix 701. Motor Drives 1 Tue 25 August 2009 21:41
True Torque of a Servo motor for comparison to a Stepper motor, when used in a router Mcyoda Motors & their mountings 3 Tue 19 August 2008 01:50
K4- Bipolar Stepper Controller Board javeria The Market Place 0 Tue 29 January 2008 19:26
The SuperTech GeckoPwr IV Electronic Micro Step Motor Controller Gerald_D 70. Control Systems 0 Thu 06 July 2006 11:12
