Thread Tools |
Used skate
Anyone have a used Grind Head - Assembly they are done with and would be willing part with?
Thanks Chuck |
Chuck,
When you order the laser parts, the parts to build the grinder assembly are included in with the other parts. Look at parts M6 10 100 - and beyond of the drawing package. You will see the parts for the grinder. Hope that helps you. |
Thanks Nils,
I saw those drawings, but I just can't afford $500 in laser cut parts at the moment. I do have access to some inexpensive angle, and a 4.5" grinder and wanted to get a start. This seemed like as good a sub-project to start with as any. So if anyone has a used skate grinder assembly that they would be willing to part with, please PM me. Thanks |
Chuck, I just PM'ed you.
Joe |
Chuck
The eccentric bushes of the skate are mostly removed for building the z-slide. That means you will probably not be offered a complete skate. |
Altough I had both parts for the skate I did not use it the way it was intended to be used and I must say that it did work well.Try and get the part that go onto the grinder that is all you need and some brainwaves ( sorry I don`t know the part number have not even had coffee yet )Look at my tread there should be pic`s.
