Old Sun 26 February 2012, 03:51
Gamsa47
Just call me: Marinus
Pretoria
Just Starting Out
Hi, Im from SA Protoria.
What is the cutting dimmentions on a MM? Can in handle a full 2750x1850 board? If not is the planns to build a bigger MM available?
Old Sun 26 February 2012, 03:56
Gamsa47
Pretoria
Hallo.
How much do I budget for a MM?
I need some South African answers please.
And also tell me if you manufactured the parts locally or not.
Thanx (Dankie vir al die SA antwoorde)
Old Sun 26 February 2012, 07:34
Ja jy kan so een bou lees net die planne dan sal jy sien wat jy moet doen om `n 9x6 sny area te maak.Alles wat op die masjien is kan plaaslik vervaardig word kontak vir my of Kobus of stuur`n PM ons het van die parte.Jy kan solank vir so R35 000.00 Budget.
Old Sun 26 February 2012, 15:04
When you get the plans, you will find it is expandable and can even be made smaller to some reasonable extent to suit your needs.
Yes it can handle the size you requested, if you follow the plans.
Starting up in AZ Mojo Construction started, but not cutting yet 43 Wed 15 January 2014 07:46
Starting Up in Atlanta ga. kimbrell Introduce yourself and start planning 11 Mon 09 May 2011 22:42
Starting to make progress peter__jackson Construction started, but not cutting yet 7 Wed 27 October 2010 11:28
New Guy Starting Build oscaryrc Introduce yourself and start planning 1 Sun 08 August 2010 18:52
Starting point for motors. tangocharlie123 Motors & their mountings 5 Mon 19 July 2010 23:53
