Old Mon 19 July 2010, 06:47
tangocharlie123
Just call me: Pete
Gatton Brisbane
Starting point for motors.
Would these be good as a starting point
http://ausxmods.com.au/stepper-motor...-stepper-motor (MetalHead fixed the Link)
these seem to be the same as the kellinc motors with the same model no.
This gent also has Gekos at a reasonable price
I was thinking of a G540 as a starting point then move upto the 203v's at a later date.. or maybe the leadshines
A lot of reading today but a lot of info found out.
Peter
Old Mon 19 July 2010, 07:08
Your link didn't work, but assuming you meant the 640 Oz/In Nema 34, 34H280-45-8A on that site, then yes, it's in the right kind of range. Note that it is not a perfect match for the G540, so think it through carefully.
Old Mon 19 July 2010, 14:12
I will say this. Do what you want the first time around. EVERYONE will almost NEVER go back in and make changes to the machine once it is up and running.
Unless you are upgrading to belt from direct or making more movement in the Z drive etc.
Going back and undoing something that works will be hard to justify once the machine is up and running.
Just my thoughts and this is not just to the MechMate, but life as a whole. Do what you want the first time around. It may take a little longer, but you'll be happier in the long run.
Old Mon 19 July 2010, 19:06
<sniff> I smell wisdom floating around. Good point, Mike.
Old Mon 19 July 2010, 22:42
tangocharlie123
Just call me: Pete
Gatton Brisbane
Thanks Mike and Brad
Wisdom taken.
my thought would be
"Do it now and ask for forgivness Later"
Cheers Peter
ps Mike how do you edit a post as I was going to fix the link at 2-30am my time.
(editing old posts is the art of the master .... ie I have rights to do it others don't)
Old Mon 19 July 2010, 22:53
I agree 110% with Mike. I put my machine together and ran it for 2 years AS-BUILT....only changed the drivers to UI ROBOT types....just because I wanted to do it. Have thought about gearing it, but never got around to do it. I am even putting off replacing the spoilboard....it looks bad, but what the heck, it still works.
Just to say hi.. and point folks in the direction of some FREE software. yohudi Archives 8 Sat 27 August 2016 16:58
Dead Gecko's in S.Africa - a collection point for bulk return for repair Gerald D 701. Motor Drives 8 Fri 09 July 2010 12:21
new machine - High Point, USA thereclinerman Introduce yourself and start planning 1 Wed 11 November 2009 09:55
Setting up the 0,0 point for a job . . . . Gerald_D General - MM Operating 18 Tue 07 April 2009 17:56
