Old Sat 05 February 2011, 06:15
Red_boards
Just call me: Red #91
Drilling Gantry for cable chain support
I see that the cable chain support is bolted to the gantry tube. I can't find a plan detailing this. Is it necessary to use a clamp strip for this or can the thin beam walls support the weight?
Old Sat 05 February 2011, 07:31
JamesJ
Kansas
I drilled and tapped the gantry tube. The recommended minimum thread depth for 6 mm is around 4.7 mm and the thread depth in this case is around 3.1 mm. As long as you do not overtighten I think it will be fine.
Old Sat 05 February 2011, 09:11
I used big self-tapping screws. Big blind rivets will also be okay. The wall is thick enough to carry that light load.
Cable chain ("E-chain") - sizes and sources Gerald D 60. Wiring & Cable Management 73 Tue 02 October 2012 14:59
Australian Cable Chain (also distribute worldwide) Besser 60. Wiring & Cable Management 1 Tue 08 September 2009 21:28
Drilling the gantry tubes and fixing the Y-Rails Gerald_D 20. Gantry 12 Wed 07 January 2009 21:04
Alternatives to expensive cable chain Kobus_Joubert 60. Wiring & Cable Management 7 Wed 16 July 2008 07:21
Cable chain - E-Chain sizes & sources Evan Curtis Archives 33 Sat 10 November 2007 12:27
