-   20. Gantry (http://www.mechmate.com/forums/forumdisplay.php?f=23)
-   -   Drilling Gantry for cable chain support (http://www.mechmate.com/forums/showthread.php?t=3272)
Red_boards Sat 05 February 2011 06:15
I see that the cable chain support is bolted to the gantry tube. I can't find a plan detailing this. Is it necessary to use a clamp strip for this or can the thin beam walls support the weight?
JamesJ Sat 05 February 2011 07:31
I drilled and tapped the gantry tube. The recommended minimum thread depth for 6 mm is around 4.7 mm and the thread depth in this case is around 3.1 mm. As long as you do not overtighten I think it will be fine.
Gerald D Sat 05 February 2011 09:11
I used big self-tapping screws. Big blind rivets will also be okay. The wall is thick enough to carry that light load.
