Old Mon 28 December 2009, 13:37
paul60
Just call me: woodguy
st george
Barbados
shutdown problem
if i shutdown my computer before i shutdown the controller
i get a loud thump and the x axis lurch forward about 1/2 inch. i do not have this problem if i shutdown the controller
then the computer
definitely a problem there.
I am running mach 3 on a shopbot this is a home built controller
now setting it up for the first time.
thanks paul
Old Mon 28 December 2009, 13:51
Paul,
do you have the charge pump connected and enabled on the BoB and in Mach3/EMC?
Ries
Old Mon 28 December 2009, 14:35
paul60
st george
Barbados
i have setup the charge pump in output signals enabled port 1 pin 1
in mach3 on jp3 the link is on non estop fault and outputs enabled
on jp2 link is on always and pin 2-9 enabled
thanks
Old Mon 28 December 2009, 15:53
Paul,
if you have JP2 on 'on always' (jumper close to the centronics port), then this means that you don't use the charge pump but instead you tell the BoB that you always want to have the system on 'on', meaning that the outputs always follow what the inputs do, given that teh estop is not in fault.
So, when you stop the PC, there might be some random signals going which might make the steppers to turn.
My suggestion is to reconfigure the BoB to put the jumper on "OK" and configure Mach3 to use the charge pump, it might just aswell be that you did configure Mach3 already but it was just the jumper in the wrong position.
If you move Jp2 over to "OK" and the machine works, then all is fine. When you turn of the computer you shouldn't see the MM moving anymore.
Ries
Old Mon 28 December 2009, 16:56
paul60
st george
Barbados
i move the jumper over to ok machine works but same problem.
look like i will have to switch the controller off first i am sure its random signals that is causing the problem.
i got this reply from a moderator on mach 3 forum.
That sounds pretty typical if you are using the printer port.
Mine clunks too but 1/2" is quite excessive !
Best to do as you are and kill the controller first, or at least install a switch to disable the drives before killing the PC.
The port does weird things while booting up and shutting down.
Could do damage if you were very near a limit switch or hard stop.
RC
if i decide to not use the printer port what can i use and what is involved .
thanks paul
Old Mon 28 December 2009, 17:19
Paul,
I forgot to look at JP3, my bad.......
From the manual : If you do not wish to use the charge pump feature, change jumper JP3 to the “not EStop/Fault” position.
Can you also change JP3 to : 2 to 3 CP-OK & not EStop/faultControl , since I think you have that set to not EStop/faultControl
sorry for the confusion.
If you are into electronics, check http://www.pmdx.com/Doc/PMDX-122_Manual_111.pdf page 16, Figure 7
If you don't want to use the parallel port you could use a smoothstepper : http://www.warp9td.com/, but from what I understand it's still beta so I wouldn't use it yet.
Ries
Old Tue 29 December 2009, 01:06
I have to turn off my controller before I turn off my computer or the router runs. It is no big deal for me.
Old Tue 29 December 2009, 06:04
paul60
st george
Barbados
z plate wiring
thanks for all the help i believe i am just about finished except for the z zero
plate physical connection where does it connect on the controller
thanks
Old Tue 29 December 2009, 06:43
Paul,
I don't have any experience with axis zeroing (auto zero??) as of yet...
However is your problem of the x-axis lurking forward solved?
Ries
Old Tue 29 December 2009, 06:48
paul60
st george
Barbados
lurking forward still there doing what nils does turn off controller first
Old Tue 29 December 2009, 07:46
Woodguy,
I have to look at Mach to see which one I am connected to. It is cold here for FL so I went out to check. In Ports N Pins, Input.... probe pin 11 for me.
If you have additional questions, let me know.
I may come visit you to see your build.....it would be nice to see some clear water. Do you sail?
Old Tue 29 December 2009, 08:28
paul60
st george
Barbados
yes nils i race on a 30ft and 53 ft Beneteau also do alot of deep sea fishing went fishing on sunday the fishing season is now starting jan - april is best
what about you?
so what do you use your cnc for?
all woodwork here www. timberline-furniture.com
hoping to get this controller working building the controller was the easy part
just cant seem to get the configuration right.
paul
Old Tue 29 December 2009, 13:40
Woodguy….
Any job opening as I would like to think a stroll out in your area would be a little warmer than around here with today at a warm -22°C
Working with a MechMate in warm weather year round…I can see that !!!!
Amicalement, Robert
Old Wed 30 December 2009, 05:42
paul60
st george
Barbados
its not all pleasure working in 85 deg and a high humidity
i think 65 deg would be perfect.
paul
Rack is bowed - is it a problem? KenC Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 5 Mon 14 December 2009 11:54
Problem with Main Longitudinal Beam gixi 10. Base Table 32 Thu 19 November 2009 15:23
Would you mind to help me to solve the problem for Keling stepper Motor Driver? qangel1000 Motors & their mountings 6 Sat 08 August 2009 00:42
Cutting in the UK! Electrical noise problem solved! - Darwen, UK Barrie MechMates already cutting 5 Fri 01 May 2009 10:25
Kitchen table project started - Antek Power Supply problem KevinL Construction started, but not cutting yet 6 Fri 22 February 2008 22:10
