Old Mon 14 December 2009, 05:11
Rack is bowed - is it a problem?
Hi,
I don't remember reading the required quality of the rack. Please do remove if this has been discussed elsewhere.
My racks have some bow in/out/side a little, about +/- 1mm over 60cm (I place a frame square over it & measure the gaps.) Will this be a problem?
Old Mon 14 December 2009, 06:44
1mm in 600mm sounds straight enough. I am sure that you can close that with one finger's pressure and the tape should hold that with no problem.
Old Mon 14 December 2009, 07:26
Thanks again for a fast reply, one question leads to another. I also observe that I can't mash 2 racks teeth to teeth perfectly, is this a problem?
This is on the right end
this is on the left end
Old Mon 14 December 2009, 07:46
Mach allows you to compensate for these differences (see "screw mapping") but I havn't heard that this is used for racks. What does your supplier say about his quality? It may be his normal standard . . . .
Old Mon 14 December 2009, 08:01
I have not ask them yet. My pass experience with racks are module 10 and larger, they normally mesh up nicely with acceptable tiny gaps but Module 1 is so small & I'm puzzled.
This one looks like there is a cumulated error along the whole length...
Old Mon 14 December 2009, 11:54
Claudiu
Just call me: Claus #43
Arad
Sorry to see this.
Have you tried brushing along the teeth with a wire brush to be shure no leftover steelparts are inbetween teeth? I had the same leftovers and wondered why they don`t fit 100%.
Yes, I`m a dentist and I`m obsessed with leftovers between teeth.
Problem with Main Longitudinal Beam gixi 10. Base Table 32 Thu 19 November 2009 15:23
Would you mind to help me to solve the problem for Keling stepper Motor Driver? qangel1000 Motors & their mountings 6 Sat 08 August 2009 00:42
Cutting in the UK! Electrical noise problem solved! - Darwen, UK Barrie MechMates already cutting 5 Fri 01 May 2009 10:25
Rack alternate Art Archives 5 Fri 12 September 2008 13:04
Kitchen table project started - Antek Power Supply problem KevinL Construction started, but not cutting yet 6 Fri 22 February 2008 22:10
