Old Mon 11 January 2010, 15:49
PEU
Just call me: Pablo
Buenos Aires
Question How do you make solid wood doors?
I have no woodworking background other than some simple work at home, in advance to making my MM in the near future, I would like to know some tricks from more experienced users.
I want to know how to make a solid wood door
Look at some very nice examples here: http://www.portae.info/DUgallery/type.asp?iType=34
Im sure these aren't made from a solid piece, because there aren't trees that wide Im sure there is some clever joinery to make them look like a solid piece. Anyone knows a tutorial on how these are made?
The MM its suitable of doing this work for sure, I know it takes a lot of time, but these doors, when done nicely can fetch $1000's
I want to learn, can you guys teach me?
Thanks!
Old Mon 11 January 2010, 17:41
Pablo those are raised panel doors. Check out these links for more info, pictures are worth a thousand words. You could do the rails and styles on a router table and then do the carving on the center sections with the MM. There are also programs for CNC (Free doors is one) that you can use to route look alike doors from solid wood (mdf etc). Entry doors are similar, they just use larger rails and styles.
Rasied Panel Doors
Or Here
Google is your friend for more reading.
Old Mon 11 January 2010, 18:18
PEU
Just call me: Pablo
Buenos Aires
that was the missing link "Raised Panel Doors", I didn't knew the term
Old Mon 11 January 2010, 19:28
No problem, they are actually fun to make. Hoping to dress mine up with my MM when its finished.
Old Mon 11 January 2010, 20:53
PEU
Just call me: Pablo
Buenos Aires
Thank you! Thank you! Thank you!
I just finished watching this video: http://www.youtube.com/watch?v=iEtFvFwsaHY
It explains in great detail what I wanted to learn, now I guess I should start looking for router cutters
Old Mon 11 January 2010, 20:56
Pablo, that is a good video. Please be aware that most bits on the market are for cabinet doors. For entry doors, they are a little different as you need the profile on both sides. They are available though. The entry doors are of course thicker as well. Hennie is the expert in this department here I believe.
Old Mon 11 January 2010, 21:49
PEU
Just call me: Pablo
Buenos Aires
Well, lets wait for his advise, yours has been great
I guess you are referring to this kind of cutter right? http://www.freud-tools.com/fr99enindoro.html
Pablo
Old Mon 11 January 2010, 23:40
Pablo, to do cabinet doors those router cutters should do the job keep in mind the amount of doors you are going to make and how many times you can sharpen the cutter.Each time you sharpen the cutter you need to change the shimms on the cutter to accomodate the tennon to fit flush.If you are going to pump out volumes get a spindle with a feeder as you get a better even cut along the length of your rails and styles.The MM should do the job on cutting the inside pannel with the right cutting file.I am currently busy playing with a cutting file for the raised pannel doors by using 3 cutters,must say get enough wood to practice on before you go into production.I would say that if you are going to do a once off door as per the link above go for the router tip set with a good hand held router and cut the inside raised pannel on the MM.
Old Tue 12 January 2010, 00:09
If you really want solid wood front doors, are your trees are not wide enough, then there are techniques for joining planks. An important technique, with an unusual name is a biscuit joint.
Samples of solid wood doors - these are 80" tall by 47" wide
Old Sat 23 January 2010, 14:40
Johannescnc
Just call me: John
Hannover, DE
Germany
I used biscuits on miter joints for door and window casing. very easy to work with. but you don't need the special tool to make them when you have a MechMate!
3D butterfly on solid wood coaster Castone The Show Room 5 Fri 29 May 2009 22:06
Solid Edge 2D is now free vadeem Graphics & CAD 1 Thu 28 May 2009 22:16
Extruded wood? - actually a composite of wood and recycled plastic . . . . . Gerald D Miscellaneous / General / Whatever / Catchall 2 Wed 02 July 2008 23:51
Cutting mdf doors, laser coming? #1 - Sri Lanka fabrica MechMates already cutting 192 Wed 23 January 2008 22:17
