Closed Thread
Old Wed 27 May 2009, 18:27
Castone
Just call me: Leo #41
Soddy Daisy , Tn
3D butterfly on solid wood coaster
Attachment 4715
Here is a butterfly that I made for a coaster. It is about 3" in Dia. It has not been sanded. It was ran on a Mechmate machine.
  #2
Old Wed 27 May 2009, 21:21
Jayson
Just call me: Jayson #18
Horsham
Nice work Leo.
Time to try some 3D myself I think...
Jayson.
  #3
Old Thu 28 May 2009, 04:06
Leo,
Very nice. Now, try recessing the butterfly so that it is below the surface of the inner surface. I like the way you rounded the outer ring. If you change the stepover, you might be able to eleminate the lines that your 1/8 ball nose left on the inside of the wings. I had that problem when I did some grapes in corian.
Your machine is square. It is great when you don't have to sand.
Lets see more pictures.
  #4
Old Thu 28 May 2009, 04:53
Havn't done it myself, but apparently it helps a lot to get the tooling marks going in the grain direction - helps with the sanding.
  #5
Old Fri 29 May 2009, 05:28
...a little workshop note I have had success with in the past.
Before you make your final cutting pass, assuming you have a roughing tool and final finish tool, I do the following:
-rough the part with the 1st tool
-spray with a very "light" mist/layer of water to raise the grain of the wood.
-wait about 20 minutes
-parallel finish cut with at least 60% step over
Depending on your humidity, raising the grain helps the fibers to be cut stand up. Thus, when you cut the final pass, the wood will sometimes "shrink" a little bit and give a little tighter grain that needs "less" sanding.
Good luck.
* this worked well with Conifers (like redwood, cedar, soft pine) Maple and Ash not so much
  #6
Old Fri 29 May 2009, 21:06
Castone
Soddy Daisy , Tn
Lion
Attachment 4724 This one was cut from pine using a .042" end mill
Closed Thread
Solid State Relay (SSR) for switching Router under control of Mach3 Gerald_D 70. Control Systems 77 Tue 07 January 2020 18:43
Carved coat rack #41 Soddy Daisy, Tn Castone MechMates already cutting 43 Sun 17 January 2010 03:21
Solid Edge 2D is now free vadeem Graphics & CAD 1 Thu 28 May 2009 21:16
Milwaukee Router weirdness - SSR (solid state relay) not suitable jeffh Troubleshooting 26 Thu 26 March 2009 12:03
