Old Thu 24 July 2025, 21:26
peter22
Just call me: Peter
New York
Stepper Motor Issue on MechMate CNC
Hi everyone,
I’ve run into a problem with my MechMate CNC and I’m hoping someone here has seen this before or can point me in the right direction.
The setup:
MechMate CNC (custom build)
Stepper motors: NEMA 34 (8.5Nm)
Drivers: Leadshine DM860A
Controller: Ethernet SmoothStepper + Mach3
Power supply: 68V DC, 10A
The issue:
Out of nowhere, one of my stepper motors (Y-axis slave) started stalling and skipping steps intermittently during cutting. It sounds rough, like it’s fighting against resistance, but mechanically everything moves freely by hand. The motor also gets noticeably hotter than the others after a few minutes.
What I’ve tried so far:
Swapped the driver with another axis → problem stays with the motor
Checked wiring and connections → all solid, no broken wires
Reduced acceleration and velocity in Mach3 → helps a little, but still skips
Checked motor shaft for binding → smooth when rotated by hand
Verified motor tuning and current settings → seem correct
Questions:
Could the stepper motor be partially damaged (e.g., demagnetized or winding issue)?
Is there a good way to test the motor without special equipment?
Could this be a sign of failing insulation or internal short?
Any help or suggestions would be greatly appreciated. I’d prefer not to replace the motor unless I’m sure it’s the cause.
Thanks in advance!
Why a stepper motor should not be too big . . . . Gerald_D Motors & their mountings 6 Wed 11 March 2020 01:20
Chinese Spindle Issue sphericos 50. Toolheads 1 Sun 04 November 2018 06:35
Stepper motor & Driver from Oriental motor steven29 701. Motor Drives 17 Sun 17 May 2015 11:20
True Torque of a Servo motor for comparison to a Stepper motor, when used in a router Mcyoda Motors & their mountings 3 Tue 19 August 2008 00:50
