Old Thu 16 January 2025, 00:19
leon22
Just call me: Leon
New York
Problem with stepper motor?
Hello everyone,
I'm currently building a gantry milling machine. For this I purchased 3 NEMA 23 stepper motors and a controller based on TB6560 on oyostepper.
Now that I have all three motors connected, I noticed that one of the motors is behaving strangely:
When starting slowly, it bounces back and forth before starting to run normally. However, which direction it turns is accidental.
The other two engines run absolutely problem-free. I then swapped the motors and the control crosswise, but the behavior of the motor in question remains the same.
I can therefore rule out a control error. A measurement of the resistance of the connected windings showed approx. 1.6 ohms for all motors.
So the windings are apparently OK.
The only way I can explain this is that the windings in the supposedly defective motor are somehow wired incorrectly. As I said, the engines are brand new.
Has anyone ever had something similar?
Thanks in advance
Old Sun 19 January 2025, 05:10
alan254
Just call me: Al #95
mystic ct
ck the grubber screws on the shaft.
Stepper motor & Driver from Oriental motor steven29 701. Motor Drives 17 Sun 17 May 2015 11:20
Stepper motor speed problem. shikha829 70. Control Systems 4 Mon 19 September 2011 06:50
Would you mind to help me to solve the problem for Keling stepper Motor Driver? qangel1000 Motors & their mountings 6 Fri 07 August 2009 23:42
True Torque of a Servo motor for comparison to a Stepper motor, when used in a router Mcyoda Motors & their mountings 3 Tue 19 August 2008 00:50
