Old Tue 21 February 2023, 23:42
AccTekcncLaser
Just call me: AccTekcnc
Jinan
China
What should be paid attention to when using laser cutting equipment for typesetting
Many enterprises use laser cutting equipment in cutting operations, and when using laser cutting machines for typesetting, naturally there are many matters needing attention. This is why the final typesetting effect of the same device is completely different. Today, we will talk about what should be paid attention to when using laser cutting equipment for typesetting.
https://www.acctekgroup.com/uploads/...2105111PZ1.jpg
Pay attention to the lead setting when using laser cutting equipment for typesetting. In order to better connect the gap after cutting, the best way is to reference a transition line at the beginning and end of the cutting operation, namely the leader line and tail line. It should be within the scope of the artifact. Also pay attention to sharp corners and other places that do not radiate heat, even the leads.
In the operation of laser cutting equipment, naturally pay attention to the problem of hole edge cutting. Combining two parts, or even more hole edges, can reduce cutting time and improve work efficiency.
What I just mentioned is the matters needing attention when using laser cutting equipment for typesetting. Although this is a small matter, it can determine the quality and efficiency of cutting work, so it is best to understand this knowledge before cutting. What should be paid attention to when using laser cutting equipment for typesetting
Diffusion of domestic laser cutting machines and advantages of laser processing AccTekcncLaser The Market Place 0 Sun 29 January 2023 23:24
Where you can find from least to most affordable equipment! stanron The Market Place 4 Tue 09 August 2011 05:27
Welding equipment & techniques smreish General - MM Build 96 Mon 22 November 2010 00:48
Laser Cutting Parts lisawaa The Market Place 6 Tue 14 September 2010 12:07
Laser cutting in various countries . . . . vadeem Archives 12 Thu 02 October 2008 07:02
