Old Thu 08 July 2021, 08:31
paul60
Just call me: woodguy
st george
Barbados
how to slave x motors
I have a shobot prt 96.
when i tried to run this morning it jump the rail found out x motors moving in
the same direction. need advise in resetting the slave . is there a step by step
instructions anywhere ?
If anyone can help thanks paul
Old Fri 09 July 2021, 16:04
DocTanner
Just call me: Don Ross
Blue Ridge, Texas
I believe Shopbot use their own software. Mechhmates typically use LinuxCNC or Mach.
I'm sure the guys over at http://www.talkshopbot.com/forum/forum.php will be able to help you.
Mach3 X axis with 2 motors set as slave viz 70. Control Systems 7 Sat 08 September 2012 08:58
