Old Sun 18 May 2008, 13:33
foinikas
Just call me: Sakis
Trikala
Greece
Construction started - Greece
I am exiting of this project,i was making a search for cnc routers and got this site I'm wood sculptor and i was looking for a router that can help my work.
Mechmate Looks great for my work i have download the PDF files and watch the
videos and photos in this site.I would like to ask If someone else is from greece and help to understand the plans and give me some help about the general plan
of this machine My Mechanic knowledges isn't great.
Hi from greece one more time.Good work.
Neither my english.
Old Sun 18 May 2008, 14:59
Foinikas,
Welcome to Gerald's MechMate.
I don't believe there is anyone else that has signed in that is from Greece. There are many here like you that do not have much experience with building a machine like this but there more experienced builders that will be happy to help you. Just ask and good luck with your build.
Old Thu 22 May 2008, 06:41
foinikas
Just call me: Sakis
Trikala
Greece
I would like to ask How i should start to build my mechmate. i Need cuting area 1500mm X 1000m.I have download the pdf files take a look on them (Great Work very detailed) and i would like to ask:
1. Because in greece step motors are very expensive and because is my first try
to build something like this,i am thinking to order them from another country In europe or Usa.I would like to suggest me Some motors to Look or buy.
2.If i understand well The step motors have there own control unit that you need to Build in a panel (Box),or I need to make a Control center As the pdf
File describe?
If hope my first try to go well.
Thanks for your time,and sorry for my english isn't so good.
Old Sat 24 May 2008, 12:48
WTI
Just call me: James
Detroit (Michigan)
Sakis, I know this site is very large and it can take some time to know where everything is.
Start here for the motors you will need:
http://mechmate.com/forums/showthread.php?t=254
You need to build a control center box, then put the "MOTOR CONTROLLERS"
inside of it:
http://mechmate.com/forums/showthread.php?t=278
Keep studying the plans and reading on the forums. It takes about 80 hours of study to learn it all, and a little longer for those who need to translate the English language into their own .
Old Sun 25 May 2008, 04:25
foinikas
Just call me: Sakis
Trikala
Greece
Thanks for the Help.
My current Status is : I am translate the PDF files Located at Download section Because i cant Build it my own i ask the help of an expert friend in metal construction I also check the motors and as i understand a good choice is PK296A1A-SG7.2 motor with gecko G202or G203v(Please make the proper changes if i am wrong). I have contact already contact Oriental Motor (Impossible to find step motors in greece in a fair price) and ask about Reseller in europe .
Also reading the site I see the use of PMDX-122 is this what i also shall use or go to something like pmdx-131or pmdx-132 to avoid any mistaces from my side (a bit easer to connect it i dont understand lot of terms you use).
And the last What power Supply shall i use is any ready kit to suggest me
we use in greece 220-240v ac at 50-60hz.
Thanks for Your support !
When pdf translated and want i can upload it.
Thanks again Sakis.
Old Sun 25 May 2008, 04:42
Sakis my 1st choice would be the gecko G203V it is much more user friendly because of it's forgiveness when it is wired wrong.
Old Sun 25 May 2008, 18:43
I believe that the PK296A2A-SG7.2 is preferred by most with the G203V due to its better torque curve and lower inductance that makes it a good match for the G203V.
Old Tue 09 June 2009, 06:32
foinikas
Just call me: Sakis
Trikala
Greece
After long time away im back to action i will start to construct it asap i will order the motionking motors 34HS9801 for start
Here is the reply from MK
Yes, you can use our SM-82A. Its price is $85.00/pcs. They can be delivered together with motors within 8 working days. If so the updated cost is as below:
SM-82A, $85.00/pcs, 4pcs ----------------------- $340.00
34HS9801, $50.00/pcs, 4pcs ------------------- $200.00
Express Freight Charge --------------------------- $210.00
PayPal Surcharge (5%) --------------------------- $37.50
SUM ------------------------------------------------------ $787.50
Pls confirm and advise
but i would like to ask about the Drive since i read that in the start they was recomend another type of drive -2H090MK ( http://mechmate.com/forums/showthrea...g+drive&page=4 ) Post 99.
So i would like to ask Shall i order them or stay on gecko I consider the money since my budget is limited for this (I buy another cnc and it was a failure).
Here is the Link to the Drive Page: http://www.motionking.com/Products/D...or_drivers.htm
And the Pdf for the SM-82A http://www.motionking.com/download/S...tion_Rev.E.pdf
I will not order the drive unless Ppl in this forum say that will work .
Thanks. Sakis
Old Tue 16 June 2009, 04:13
gorantec
Just call me: gorantec #59
bitola
Macedonia
Sakis
i have recieve this drivers http://www.driver-motor.com/ProductContent.aspx?ID=51 i will test in couple days and let you know .And also they have cheap motors you can check at theat website.
Old Wed 08 July 2009, 10:48
foinikas
Just call me: Sakis
Trikala
Greece
Construction started photos will be post soon
Old Tue 10 November 2009, 08:39
Sergio-k
Just call me: Sergio #61
Athens
Greece
Hi there
i think i found my soulm8 from Greece.
I'm planing to start my own MM in a couple of days and i would greatly
use some help.
Old Tue 10 November 2009, 19:38
Originally Posted by Sergio-k View Post
Hi there
use some help.
Welcome Sergio,
so there is a Greece build and a soon to be Greece build, right?
Plenty of people here to help out and no worries, you don't have to be a rocket scientist to build a MM. We also have a 'Introduce yourself and start planning' forum here in case you are not sure yet even what size to build and just in a planning phase.
http://www.mechmate.com/forums/forumdisplay.php?f=88
Ries
Old Tue 08 December 2009, 10:04
foinikas
Just call me: Sakis
Trikala
Greece
Here is the 4 Gecko g203v with pmdx 122 and the MK motors.
Also here is my table i work reeeeeeally slow.
I suggest this option to add in the Mechmate i use it i my current router and proved helpful please let me know what you think about it.
http://img521.imageshack.us/i/imgp0264.jpg/
Here some other photos from my current cnc and a sample of my brothers work since he is the artist not me.
http://img687.imageshack.us/i/imgp0252d.jpg/ High res
http://img340.imageshack.us/i/imgp0497.jpg/ High res
http://img692.imageshack.us/i/imgp0496n.jpg/ High res
Handmade mirror frame High resolution.
http://img689.imageshack.us/i/imgp0159.jpg/
Closer image High resolution.
http://img13.imageshack.us/i/imgp0161h.jpg/
Old Tue 08 December 2009, 13:53
Claudiu
Just call me: Claus #43
Arad
Hello Sakis,
Good luck with your build...and absolutely beautyful Mirror Frames.
Claus
Old Wed 09 December 2009, 23:59
hello sakis - nice machine and good luck on your mechmate - what is the wood material you have used for the mirror frame??
Old Thu 10 December 2009, 04:50
foinikas
Just call me: Sakis
Trikala
Greece
the wood called "Flamouri" in greek i think the english translation is Lime tree.
here is wiki link http://en.wikipedia.org/wiki/Lime_tree
Old Thu 10 December 2009, 07:46
Claudiu
Arad
... Handmade mirror frame High resolution.
Sakis, is it handmade with the router or really handmade?
Anyway its nice.
Claus
Old Thu 10 December 2009, 08:34
foinikas
Just call me: Sakis
Trikala
Greece
CLaus,
Ofc and is handmade my brother is a wood sculptor and his main work is to hand carving furniture decoration.
Check this also:
http://img16.imageshack.us/i/015rd.jpg/
http://img15.imageshack.us/i/imgp0467q.jpg/
Old Sat 19 December 2009, 02:30
tomsitas
Just call me: tommy
ioannina
Greece
hello from GREECE...
NICE FORUM ...
SORRY TO BOTHER YOU WITH SOMETHING OUT OF THE SUBJECT
BUT I NEED SOME INFORMATION FROM THE GREEK FRIEND ,ABOUT THE ALU PROFILE IN HIS UPLOADED PHOTOS....
"HAVE YOU FOUND THE ALU PROFILE FROM SOMEWHERE IN GREECE ? OR IS IT IMPORTED" .
NEED ANY ADDRESS OR EMAIL IF AVALIABLE .
THANK YOU..
Keep up the good job
will be in touch.
[email protected]
Old Fri 25 December 2009, 05:29
foinikas
Just call me: Sakis
Trikala
Greece
Merry christmas to all with the best wishes for the new year may bring you health and luck
and give you more creative ideas to continue planing!
Cheers to all of you!
Old Thu 31 December 2009, 10:13
foinikas
Just call me: Sakis
Trikala
Greece
Happy new year !
i hope the new year find you healthy and bring you luck to you and your familys!
