Old Fri 02 May 2008, 05:34
isladelobos
Just call me: Ros
Canary Islands
Spain
Rack & Rail all in one . . . .
This is an all in one rails an rack
http://www.gudel.com/
Old Mon 05 May 2008, 13:45
turnerseng
Just call me: andy
PMB
What about using this:-
http://medias.ina.de/medias/en!hp.ec...H;bv6l0bni_nq7.
It should bolt straight on.
Old Mon 05 May 2008, 15:01
It should but…Ask for a quote on those rail & the needed rollers (since the Dual-vee will not fit) and you’ll come back to the simple Dual-vee ones !!
Robert
Old Mon 05 May 2008, 16:26
dmoore
I can only imagine how expensive that rail/rack combo is.
Old Mon 05 May 2008, 22:51
My old story. . . . . . . .
Those rails are weak/flexible they need to be screwed to a strong/precison foundation before they function properly. A much more complicated and expensive system than what we have now.
Feel free to use those sytems, but don't ask me to change the plans to accommodate them
Old Tue 06 May 2008, 00:50
turnerseng
Just call me: andy
PMB
What is the difference between having the angle iron machined as opposed to hand grinding?
I would think the rails machined in a mill would bow and bend alot. what happens when you grind?
How much heat is generated?
Old Tue 06 May 2008, 07:54
Andy,
I machined my angle irons and to keep them from bowing and bending, I used a lot of clamps and took relatively light cuts. Still, they didn't turn out as good as I would have liked. The problems were not from bowing and bending but rather from the setup and slack in the mill table. I definitely think that grinding with the skate is the way to go. I'll grind my next MM rails.
Old Tue 06 May 2008, 09:14
Andy,
Ditto what Doug said. I had my rails machined because I couldn't grind them properly (The skate was under develpoment then, not the case today).
My rails are fine, but not the quality I would have liked. I'll grind my own rails on the next build.
