Old Tue 15 December 2020, 20:38
SEIKI
Just call me: MARK
TROY MI.
Mounting mechanical limit/home switches
Is anyone willing to share photos of how they mounted mechanical switches.
Old Wed 23 December 2020, 11:50
rischoof
Just call me: Rik #92
Goirle
Hello mark,
I think you mean the proximity switches for homing and limiting. If you check my post in "mechmates already cutting" from rischoof (its the upper one) I posted at 23 januari 2012 some detailed pictures how they are mounted. the height they are installed depending of the specific sensing distance from you chosen sensor. (in my case 4 mm sensing distance) so I installed the 2 mm above the target. then I have enough clearance to avoid collision.
Old Thu 24 December 2020, 16:25
SEIKI
Just call me: MARK
TROY MI.
Thanks for your reply, I'll check it out.
Old Tue 29 December 2020, 04:27
rischoof
Goirle
Hello mark,
Did you found the information?
The proximity switches have fine size of threadM8*1 or M12*1.
They get delivered with two nuts. So you have to drill the hole 8 or 12 mm and use the two nuts to clamp the sensor. By this way of installing the height of the sensor can be easily adjusted
Limit Switches - optical / mechanical / proximity Gerald_D 70. Control Systems 333 Sun 24 January 2016 15:32
Using limit/home switches to autosquare the gantry Alan_c 70. Control Systems 64 Mon 28 February 2011 09:37
Home switches? giggler 70. Control Systems 4 Sun 26 September 2010 17:17
Limit / Home switches - Mechanical or Proxy? fabrica 70. Control Systems 44 Thu 21 June 2007 01:07
What's the difference between Home and Limit switches? Marc Shlaes 70. Control Systems 6 Tue 19 June 2007 07:46
