Old Wed 19 April 2017, 11:37
toad
Just call me: Toad #80
Burlington NC
Cool Spencer Vortex Blower
I have acquired an Spencer Vortex Blower Model # VB- 22G-U. 220V
I need help with the wiring, I have 9 & 3 together, 8 & 2,together, 7 & 1 together, 5 & 6together P and P are loose. Can anyone assist with correct wiring?
Old Sat 22 April 2017, 04:32
What are you hooking it to? Single or 3 phase, 110 or 220?
Old Sat 22 April 2017, 07:44
toad
Burlington NC
I was looking to use it for another vacuum system. I have single phase, so I would have to use a converter. It is already wired for 220 3 phase, but the two wires labeled "P" I don't understand.
Old Sat 22 April 2017, 16:58
timberlinemd
Just call me: Steve #66
Arizona
http://www.spencerturbine.com/wp-con..._OM_090915.pdf
Looks like it (P/P) energizes a pilot lamp.
Old Sat 29 April 2017, 11:55
if it is 3 phase motor and you have a single phase supply you will need an inverter that is capable of single phase input. Depending on the size of the motor will determine the price of the VFD.
Old Tue 02 May 2017, 13:05
toad
Burlington NC
That is correct. I have an inverter, but the P/P was confusing me. may be a pilot lamp. thought it might be some kind of a fuse. wasn't sure.
Old Thu 04 May 2017, 11:44
Actually, according to the diagram on page 3 of that PDF, P/P is labelled "Thermal Protector" and appears to be a Normally Closed thermal protection device inside the motor, which presumably goes open if the motor overheats. It is shown wired into the contactor hold in loop along with the Stop switch. The pilot lamp is simply in parallel with the coil of the contactor.
So P/P should normally complete a circuit, and if it opens, you should have the motor stop.
Old Sat 06 May 2017, 15:39
timberlinemd
Arizona
I think Brad has found the right solution.
Old Sat 20 May 2017, 11:34
toad
Burlington NC
Thanks guys, that helps a lot.
peerless blower alan254 The Market Place 0 Thu 14 March 2013 07:36
Blower Power javeria 55. Dust Management 14 Mon 27 June 2011 21:20
Blower impeller design & comparisons vishnu 55. Dust Management 30 Sun 08 November 2009 10:25
Blower Question MetalHead 55. Dust Management 3 Thu 13 August 2009 12:12
