#1
Another MM is born !!! #128 - São Paulo BR
Hello everyone!
I am from São Paulo Brazil, I work for thirteen years in the furniture industry. Four years ago I started researching the construction of a CNC router, started building my Mechmate in January 2016, the mechanical part is already finished and I'm getting some electronics now. Cutting area X2600 Y1700 mm. |
#2
Kool.
We shall watch your progress. |
#3
Everything looks great, you'll be cutting in no time.
#4
Wow,
Looking great !! |
#5
Very Nice Looking rig
#6
Thanks everyone!
#7
Finally it's time to have some fun.
Next weekend I will work hard on the project and soon I will share new photos with the assembly details.
#8
Good news
I finished the assembly and alignment for at least two months. The panel box is small but, everything is working.
Despite the warnings, I set up the frequency inverter inside the panel, did several tests and still had no problems. |
#9
First cuts
Cut 54 circles Ø900x9mm MDF, are not all in the picture.
#10
Another test
Cutting corian®, some images about cut quality.
The cut is slightly serrated, the results are satisfactory for the cutting of wood in general. The groove in the picture is 6x3mm. |
#11
RC motor cowl
Manufacturing a RC airplane motor cowl mold.
The video link, https://youtu.be/ae-kjlu-gVE Thanks everyone. |
#12
Congrats Antonio, must be nice to see it cut the first time!
Are you using direct Drive? And mach3? |
#13
Yes
I'm using Mach3 and direct drive.
Mach3 Version R3.041 Rack and Pinion module 1 The machine works smooth, fast and continuous. Do not stop while running the lines. |
#14
Machine and parts configuration.
Cutting area - 2600x1700 millimeters
Rack - module 1 Pinion - module 1 (Z24 teeth) Laser cutting and folding - http://www.blankinox.com.br/ (Osasco-São Paulo - Brazil) Bearing RM3ZZ / W3 - Chinese Electrical and electronic parts: Power supply of the control box - 220v Step Motors - Nema 34 Model (KML092-F07F) 60kg.cm, wiring in series (without reduction gears) Drivers - Gecko G201x Toroidal Transformer - 560VA (80V 7A) Breakout board - CNC MACH3 USB 4 Axis 100KHz USBCNC Smooth Stepper Motion Controller (Chinese) Spinlde - Model Tecmaf TFS.3Z3M.01 / 2200KW (3HP) ER20 Frequency Inverter - WEG CFW300 Limit switches and buttons, operate with 12V power supply |
#15
Congrats on your build!! You get #128 - Hope this inspires all those watchers out there to get moving a build their own MechMate !!
#16
Congratulations, Antonio, on earning Serial #128. Here is the Updated Builder's Log. Please check your entry for any changes you would like to make.
#17
Well done #128.
Have fun. |
#18
Thanks Gerald, Mike for the number, John # 26 to update builders log, To Al # 114, and the other members of the best forum about router cnc in the internet. I will put the number in the machine.
Thanks so much! |
#19
One more job with Mechmate.
Custom guitar PRS 22 frets for left-handed. https://youtu.be/zwjS12HiXdk |
#20
Nice. That is awesome.
#21
Congrats! VERY NICE JOB, a real inspiration for us brazilian fans of the Mechmate. After this I have to restart my project.
#22
Congrats on 128, you should be proud of your work.
Real nice job on the guitar, one of those is on my list of things to do. |
| Three weeks toil, another MM is born. | kevinbream | Construction started, but not cutting yet | 10 | Mon 30 April 2012 05:31 |
| Hello From Sao Paulo, Brazil! | luizfrds | Introduce yourself and start planning | 13 | Tue 30 June 2009 16:21 |
