Old Mon 22 August 2016, 08:17
Jonazizbey
Just call me: Jonazizbey
Dubai
United Arab Emirates
Plasma CNC to launch first cut - Need help
Hi To everyone and Thanks to the organizers of this forum, Mechmate CNC Project.
I have recently built Mechmate CNC plasma soon going to to test first cuts.
Need your help to prepare G code for floating Z axis and probe fixed CNC plasma.
This is so far I achieved,
Ref homing Z axis working, https://www.youtube.com/watch?v=hlvK...ature=youtu.be
Testing Z axis Floating Probe without G code -- is FINE https://www.youtube.com/watch?v=D09Y...ature=youtu.be
The main headache is now M899 + Probe is not working with G code. M899 is not feeling anything when Mach3 reads G code,
Its directly jumping to N0140 G01 Z1.5000 F300.0, from N0110 Z4.0000
https://www.youtube.com/watch?v=Suo4...ature=youtu.be
I tried to put different thickness materials to see if Probe works, But useless,
Below First part of G code,
Macros which dropped on macros/plasma folder also there.
What might be a problem in this? I am attaching also 2-3 photos from Configuration Menu. Mach3 THC.scpost ,
I have also attached SheetCam post processor
Please tell me where I made a mistake,
N0010 (Filename: Test.tap)
N0020 (Post processor: Mach3 THC.scpost)
N0030 (Date: 22/08/2016)
N0040 G21 (Units: Metric)
N0050 G53 G90 G40
N0060 (Part: Test)
N0070 (Operation: Outside Offset, 0, T1: Plasma, 1 mm kerf)
N0080 G00 X56.8112 Y58.7335 Z40.0000
N0090 Z4.0000
N0100 M889
N0110 Z4.0000
N0120 M03 THIS IS TURNING THC trigger relay on
N0130 G04 P0.5
N0140 G01 Z1.5000 F300.0 At This height it is cutting
N0150 G03 X60.0112 Y55.5335 I3.2000 J0.0000 F600.0
N0160 X60.0112 Y55.5335 I0.0000 J9.5000
N0170 X63.2112 Y58.7335 I0.0000 J3.2000
N0180 M05 THIS IS TURNING THC trigger relay off
N0190 G00 Z40.0000
Macro M899
Offset = -5 'set your offset in mm here
message("Detecting of material pos.")
code "G31 Z-100 F600"
While IsMoving()
Wend
Call SetOEMDRO (802, Offset) ' Set the Z axis DRO to float head switch offset
sleep(500)
code "G00 Z-2.5"
Macro M3
DoSpinCW()
Macro M5
DoSpinStop()
Old Mon 22 August 2016, 12:04
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Is mach3 licenced? In demo mode THC dont work.
Edit: I watched video. With this Ivan ....... licence Mach still works in demo mode. Try with valid licence, it may make change to mach 3 behavior.
Old Mon 22 August 2016, 12:15
Jonazizbey
Dubai
Yeap it's licenced. I have not yet connected Plasma Source and THC's power supply.
I dont know if i can test THC's work without plasma, as I know THC works with arc. lets see I will try tomorrow,
Mistake has been found with help of good master guy named Danilo, Member of this form,
problem was macro named M899 supposed to be macro M889. Post processor was issuing the whole G code under M889 code.
so I changed it 889, it started working , simple unnoticeable mistake took the whole 2 days,
Also Z axis home switch is also advised to shift up. so home position will be when torch is at the top of Z axis, that is easy I will drill another hold and shift it there,
New to cnc plasma fredholland Introduce yourself and start planning 6 Wed 30 September 2015 06:17
Another MM as Plasma Table KenC MechMates already cutting 130 Sat 10 November 2012 07:26
Plasma in Florida Jimmystractor Introduce yourself and start planning 16 Fri 18 March 2011 23:54
Plasma Cutting....anyone doing this?? Mitch_1 50. Toolheads 1 Mon 09 November 2009 16:26
