#1
Limit Switch Problems
It has been a long time since I have had any problems with my machine. I have forgotten some things. So I can use some help reminding me.
Yesterday, I was cutting and had no problems. Today, I am resurfacing so I can replace my spoil board. I kept having problems with my limit switches. I did check to see if the E-Stop switch are good. They work and are not causing the problem. The limit sensors do not have any thing between them and the metal. They are not loose. The wires are screwed in tight. The relays are not on. Which I think the indicator light should be on. I did not have a meter to check power etc. I am using proximity switches. Please remind me what I need to look for. Thanks Last edited by sailfl; Sat 11 July 2015 at 06:44.. |
#2
After doing some trouble shooting, I think the problem is a cable is bad or a connection with the cable is bad. I have discovered that the proximity sensor is good as is the relay. I have a z sensor which I am not really using so I might just use that for the y sensor.
| VFD & motor spindle safety switch | Hans | 60. Wiring & Cable Management | 20 | Tue 24 December 2013 04:47 |
| configurable limit switch. for multiple uses. | zumergido | 70. Control Systems | 0 | Thu 27 September 2012 10:39 |
| 4 inductive proximity switch selling | renraku | The Market Place | 0 | Sat 23 June 2012 07:02 |
| VFD Control Switch Question | MAC2009 | 70. Control Systems | 6 | Tue 27 September 2011 05:39 |
| Isolator switch ? | andyclarkecncuk | 70. Control Systems | 12 | Wed 24 June 2009 11:46 |
