Old Thu 16 April 2015, 13:08
Fox
Just call me: Fox
Amsterdam
Cheapest good cyclone ever - small 2" (50mm)
http://m.aliexpress.com/item/1984122...bilesitedetail
Not affiliated or anything, but from multiple fellow cnc users i hear very good reviews on this very cheap cyclone. Thought it was worth a tip for fellow mm owners
Old Thu 16 April 2015, 20:16
2" inlet/ outlet is kinda small for volume chip collection in my opinion.
Old Fri 17 April 2015, 07:56
Fox
Just call me: Fox
Amsterdam
Depends, what you are milling and for how long at a time. Sure if it you are plowing trough 18 mm multiplex all day in a production environment you need more capacity, but you won't run a vacuum cleaner then.
For most diy use I thought this might be a quick affordable off the shelve solution though I am using a different bigger system myself.
Old Fri 17 April 2015, 08:41
I think unless you are doing a 3d job with a 1/16" ballnose, a 2" hose won't flow enough volume for a MM.
I think this on a 5 gallon bucket hooked to a shopvac to use with a random orbit sander would be ideal, and am considering one for that reason. Glad you shared it.
Old Fri 17 April 2015, 13:16
It is also possible to use multiple small cyclones in parallel to get higher flow rate, and the cleaning efficiency is usually better than with one big one.
See http://lumberjocks.com/topics/46395
Old Fri 17 April 2015, 19:42
Very true, parrallel cyclone are very common in industry. One application I can think off is big 50~500ton/hr biomass boiler.
Old Mon 20 April 2015, 04:25
...or a dyson floor sweeper - with 9 mini cyclones. I push one around my house every week.
Old Mon 20 April 2015, 08:01
Heres another with free shipping, works out a little cheaper. Appears to have a ramped inlet.
I could see buying 10 for less than $225...but it seems the plumbing to split off the inlets and outlets to a 4-6" pipe, while making sure the load was balanced would be a nightmare...
http://www.aliexpress.com/item/Hot-s...216386840.html
Old Mon 20 April 2015, 20:54
You don't need spot on balance.
plumb all the inlet pipe to a inlet header box & outlet to a outlet header box. but x10 is gonna be messy.
Anyway, I'll still go for the Thien cyclone using the biggest barrel I can get my hands on the next time round
Old Tue 21 April 2015, 07:02
When I move, the plan is to go to a Pentz design, or pony up the bucks for a Clear-Vue cyclone.
Old Tue 21 April 2015, 13:09
The main reason why I wouldn't use multiple small cyclones is because of potential blockages. It is not only chips and sawdust that gets sucked into the system . . . . there are scrappy offcuts as well (sometimes even product parts).
Old Tue 21 April 2015, 15:11
Very valid point. I could also see a collection bin being hard to fab up, that wouldn't be a nightmare to empty.
I still think I'm going to order one for a 5 gallon bucket to use with a random orbit sander, so I'm glad the topic came up.
Old Tue 21 April 2015, 20:23
Speaking with Bill Pentz lately and he said he has improved the efficiency of the CV06-mini for a vacuum even further for ClearVue. I am looking to order one this week. Thought of building one but I can afford the $75 for just the cyclone mini unit.
Old Wed 22 April 2015, 06:39
I'll check it out, Pete. Thanks.
Old Sat 05 September 2020, 02:20
danieljohnson
Just call me: daniel
New Jersey
https://theedgecutter.com/best-dust-collectors/
They also list some of the best dust collector. I recently purchased one and works pretty well.
Roto-moulded cyclone Gerald D 55. Dust Management 20 Sun 09 March 2014 13:01
PK296A2A-SG7.2 in australia? Cheapest? Sudorracmecheng Motors & their mountings 4 Tue 28 January 2014 15:20
Easy way to get a cyclone if you..... Regnar 55. Dust Management 4 Fri 24 September 2010 21:23
Cyclone build javeria 55. Dust Management 75 Thu 24 September 2009 14:25
Clearview Cyclone sale WTI 55. Dust Management 0 Sat 29 November 2008 20:01
