Old Wed 17 September 2014, 12:10
IMMark
Just call me: Mark #119
Columbus Ohio
Arduino Raspberry Pi or C++
Does anyone by chance work with the Arduino, Raspberry Pi or C++ language?
I have what should be a very simple programming issue, that I can't quite figure out
Mark
Old Thu 18 September 2014, 06:39
I've worked with both systems some. You can PM me, if you want, with your issue.
Old Thu 18 September 2014, 08:28
IMMark
Columbus Ohio
Thanks John!
I will write it up and shoot you a PM.
Mark
Old Wed 15 October 2014, 13:33
IMMark
Columbus Ohio
Public Thanks!
As I am sure you all know, great bunch of guys here. I just wanted to give a public shout out to one of them. John (jhiggins7), offered to help me with a project that I was working on and having problems. John time and help was greatly appreciated!
Thanks again John.
Mark
Old Thu 16 October 2014, 08:31
Just curious...
Mark,
Just curious, were you driving your MM with a Pi?
Old Thu 16 October 2014, 15:32
IMMark
Columbus Ohio
Hi Jack
I ended up going with the Arduino, but no...not to run the MM.
The project was for some interactive props. for a stage show.
I did use the MM to make the cases.
Mark
Old Thu 16 October 2014, 19:11
Duds
Just call me: Dale
Canberra
I like the Arduino better. Though I'm not getting into the Pi/Arduino debate they're different tools for different jobs. The reason I like the arduino is its immediate, give it juice and it runs its program, no booting, no OS. I have been arguing to use it for an industrial controller but my customer won't touch due to risk. It doesn't come in a yellow box! �� I argue safety is a design issue not a certificate issue.
Old Fri 17 October 2014, 06:46
IMMark
Columbus Ohio
Yes, both are amazing little packages (and like you said, 2 different tools for different jobs). I ended up getting Uno clones for $9.99. Lot of options for those that enjoy experimenting.
Mark
Arduino Modbus danilom 70. Control Systems 3 Sun 19 May 2013 21:54
Using an Arduino to solve common interface problems Richards 70. Control Systems 14 Wed 14 December 2011 20:08
