Old Tue 12 August 2014, 13:17
Nema 34 Motor covers for the back
http://www.cnc4pc.com/Store/osc/prod...roducts_id=855
FINALLY!
For those machines that have open back motors and need a place to protect the wiring....CNC4PC has a plastic back made just for the NEMA 34 motors. Comes with mounting screws and wiring connection too.
20$ each
A bit pricey - but great solution (and they look nice)
Old Tue 12 August 2014, 21:16
wow... too expensive & its plastic, no good for heat dissipation. glue a cheap heat sink or Al foil would had do the job.
Old Wed 13 August 2014, 07:36
Fox
Just call me: Fox
Amsterdam
For normal use a stepper does not need extra cooling, and the plastic would do just fine. Steppers are perfectly ok with <80 degrees heat to work in (unlike humans ;-)). For hot countries a massive sheet to the front of the stepper would do way better in disepating heat and is also easier to make ( substitute the mounting plate in thicker alu).
A nice cover milled by the MM from stacked alu sheets with heatsink would be nice though KEN
Old Sat 16 August 2014, 05:16
ger21
Just call me: Ger
Detroit, MI
Originally Posted by Anderson255 View Post
any comment?
Are you asking a question? I don't understand your previous comment.
Old Sat 16 August 2014, 05:50
Stepper motors on a pump ?
taking back part of Stepper motor Fox Motors & their mountings 5 Thu 11 July 2013 02:26
Nema 34 set at 6000 velocity stops rotating viz 701. Motor Drives 20 Sun 21 October 2012 02:49
nema 34 saas Motors & their mountings 9 Wed 29 August 2012 04:55
Nema 42 Motor Size Question 15mgtar Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 10 Fri 09 April 2010 02:39
Do the Oriental Motor gearheads fit onto all NEMA stepper motors? alain26 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 7 Wed 02 July 2008 08:57
