Old Mon 10 February 2014, 13:15
Guip
Just call me: Guillaume
Paris
France
Hi from France !
Hello everyone,
I am Guillaume from north of France. I have been an almost full nights lurker of this forum for about two months, it is now time to start the build.
I am trying to make my own business with my laser cutters but some of my customers are waiting for larger range of material (alucobond, PVC foam, thicker MDF...etc). That is why I need a Mechmate.
My Mechmate will be :
Working area : 2500mm long x 1500mm large.
Motor : MotionKing/Deitech 86HS9801 stepper motor with 3:1 belt reducer
Drivers : Leadshine DM856
Break-out Board : PMDX 126
Controller : Ethernet SmoothStepper
Software : Mach 3
Future planned upgrade : Lateral channel vacuum pump for vacuum table (wonder the power needed for my table ?)
I started the build today.
My "you got what you paid" chop saw died after only 6 cuts, so I have to finish the job with the handheld angle saw. I hope this will be the only collateral damage even if I know the Mechmate has been designed to kill grinders...
My aim is to complete the main frame before the end of the week. Laser cutted parts should be delivered on Thursday 13th.
Some parts are laying around my shop (v-groove wheels, pulleys, racks and pinions, gas spring... ie almost all mechanical parts). Next orders will be the electronic, stepper motors and drivers and some hardware (screws, nuts...etc).
Any comment will be highly appreciate.
Bye,
Guillaume
Old Mon 10 February 2014, 18:50
IMMark
Just call me: Mark #119
Columbus Ohio
Welcome...sounds like you have a great start!
Best of luck
Mark
Old Tue 11 February 2014, 10:30
isladelobos
Just call me: Ros
Canary Islands
Spain
Hi.!!
Im following your thread construction.
For laser you no need torque and velocity, you can use small motors and power supply or controllers.
Old Tue 11 February 2014, 13:46
Guip
Paris
France
Hi Ros,
I am not building a Mechmate laser cutter, I already own a 2500mm x 1300mm one.
I just want to be able to cut material I am not currently able to cut with my laser cutters.
Old Tue 11 February 2014, 23:17
isladelobos
Just call me: Ros
Canary Islands
Spain
Now understand
Ok. nice motors and controllers, have same.
Welcome.
Old Wed 12 February 2014, 05:22
illa007
Just call me: Ilona
Warszawa
Poland
Je les bienvenus et bonne chance
Old Wed 12 February 2014, 05:33
Guip
Paris
France
Merci
Old Wed 12 February 2014, 05:49
Fox
Just call me: Fox
Amsterdam
Good Luck Guillaume,
Did you build or buy your laser cutting machines ?
Old Wed 12 February 2014, 05:54
Guip
Paris
France
Thank you.
I buit one to start my business but now I work with one I bought
Old Wed 12 February 2014, 06:41
Fox
Just call me: Fox
Amsterdam
Nice,
business has been good then.
Pictures !
Old Wed 12 February 2014, 06:56
Guip
Paris
France
Only two small pictures during the assembly. I have lost a lot of pictures after a hard drive crash.
The machine doesn't exist anymore.
It was a 90cm x 60cm and RECI 80W CO2 laser cutter. I was using LightObject AWC608 controller. It worked very fine.
Old Sat 15 February 2014, 09:39
wmarta
Just call me: Marta
Lubin
Poland
Keep informing about progress of work.
Old Sat 15 February 2014, 09:54
Guip
Paris
France
I received laser cut and bended parts on yesterday.
My fab schedule was very light at the moment I start the build. But I received huge urgent orders of laser cut acrylics parts in the last three days.
I tried to continue the drills during each job but working oily steel and highly polished PMMA at the same time is not the best I can do for my customers...
I hope the build will last forever, it will mean I have a lot of paid works for my laser cutters.
Mechmate in France - Lille jazial Construction started, but not cutting yet 38 Tue 08 April 2025 09:28
New Member from Albi, France! Pleyell Introduce yourself and start planning 11 Fri 05 July 2013 13:25
Y Car Welded - France fawzikach Construction started, but not cutting yet 30 Wed 24 March 2010 15:15
hi newbie from France romain Introduce yourself and start planning 14 Thu 03 December 2009 22:06
Donkeys being cut in France! - Galgan, France bbreaker MechMates already cutting 71 Sun 17 August 2008 20:58
