Old Thu 21 November 2013, 09:24
raju.prithiv
Just call me: Tech Guy
perth wa
Power supply insulation
hi there
i am newbie to this field of CNC and electronics, below is similar power supply that i use, i would like to know how to permanently insulate the AC part of the power supply?? is there any glue that i can buy. so that ones my wiring is done i could just insulate AC side
thanks in advance
Old Thu 21 November 2013, 21:17
Don't understand your question.
Old Fri 22 November 2013, 15:05
Fox
Just call me: Fox
Amsterdam
Hi Raju,
are you building an MM ? -> a Toroid powersupply is recommended instead of the regulated one you posted. There's a DIY powersupply section on this forum where you can find all info you need.
Not building an MM ? -> Try cnczone.com for better luck.
Old Fri 22 November 2013, 17:37
You could use, hot melt plastic gun and pour it over the contacts after you screw down the wires, if you are afraid of something getting in contact with AC clamps
Unregulated Power Supply MetalHead 702. Power Supplies 8 Sun 04 August 2013 01:57
best power supply abiyan 702. Power Supplies 1 Thu 09 May 2013 14:07
Need Help with Power Supply Selection F2DVasek 702. Power Supplies 2 Wed 19 May 2010 03:25
