Old Sun 03 November 2013, 23:47
Cirinbei
Just call me: Cirinbei
Focsani
Nou v ralyls
BUNA ZIUA TUTUROR SCUZATI ENGLEZA GOOGLE DUPA CE AN CITIT APROAPE TOATE TOPINGURILE DE PE ACEST FORUM AM DECIS SA CUMPAR PLANURILE MECH MATE. PENTRU MECANICA MASINI ESTE SIMPLU ELECTRONICA MOTOARELE NU REUSESC SA LE GASESC IN EUROPA SI NU AM PREA MULTE CUNOSTINTE DE ELECTRONICA CALCULUL Geckdrives +PK296A2A-SG7.2 : AR AJUNGE ECHIVALENTUL LA ASTA (http://www.automationtechnologiesinc...t-110vac220vac )SI PENTRU Z THK SURUB CU BILE SI MOTOR(http://www.automationtechnologiesinc...-kl-5080h)STIU CA NU A TESTAT NIMENI ASA CEVA DAR INTREBAREA MEA ESTE DACA AS PUTEA FOLOSI ACESTE MOTOARE PENTRU V RAYLS AM DECIS SA CONSTRUIESC DIN RULMENT 6207 DIAMETRUL INTERIOR ESTE DE 35 SI DIAMETRUL BILEI DE 11 AM SPART RULMENTUL SI IN INTERIOR AM PUS 2 BUC 6201 CORNOERUL ARE RAZA INTERIOARA DE 12 AM LIPIT CU LOKTIDE AM FIXAT CU POXILINA APOI AM GAURIT METRIC 4 SI AM FIXAT CU SURUB
Old Sun 03 November 2013, 23:59
Cirinbei
Focsani
V rayls test
Hello everyone Sorry ENGLISH GOOGLE AFTER READING AN ALMOST ALL toppings on this forum I decided to buy PLANS MECH MATE. FOR MECHANICAL EQUIPMENT IS SIMPLE ELECTRONIC ENGINES fail to find in Europe and do not have much knowledge of electronics CALCULATION Geckdrives + PK296A2A-SG7.2: EQUIVALENT TO THAT would get ) And z THK BALL SCREW AND YOUR NOT TESTED BUT ONE so my question is if I can use these engines for V RAYLS I decided to build 6207 Bearing inner diameter is 35 and the diameter of the balls 11 AM BROKEN RULMENTUL and inside I put 2 PCS 6201
fail attach PHOTO
Old Mon 04 November 2013, 00:09
Cirinbei
Focsani
SORRY but I learned to use this Forum
Old Tue 12 November 2013, 04:25
We'll welcome. What I can tell you is read , read, read. It will all start too make sense as you ...... Read
