Old Sat 17 August 2013, 23:50
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Mach 3 with ESS setup
I am trying to set up my PMDX-126 with ESS using Mach 3 software. I downloaded the ESS file "Installing and Configuring The Ethernet SmoothStepper" and read through the instructions several times. I went back and try to follow the step but I noticed that many of the screen prompts they mentioned were no where to be found. They must have written this another version of windows. Has anyone experienced this and found a resolution?
Old Sun 18 August 2013, 01:13
I assume you are referring to the Soigeneris instructions.
In order for the smoothstepper to work you need to set the IP of the PC network adapter to a fixed IP.
You also need to allow the Configurator to run by allowing it to do so in the Windows firewall settings both on public and private networks.
If this is too hard maybe just turn off the firewall all together at least until it is working.
Once that is done you need to turn off the ESS move the jumper on the ESS and restart it in order to program the IP address for the device.
Failing to do so just lets it boot up as if the IP is already sorted.
After programming the ESS using the Configurator turn off the ESS and move the jumper again.
Old Sun 18 August 2013, 15:32
Mrayhursh
Riverview, Florida
Thanks for the reply. I have been looking for the Configurator but unable to find it. Does anyone know where to find it?
Old Sun 18 August 2013, 21:24
Mrayhursh
Riverview, Florida
Found Configurator on Warp9 website
Another workholding setup lumberjack_jeff General - MM Operating 15 Tue 29 September 2020 02:31
PMDX 126 BOB Setup MetalHead 70. Control Systems 21 Sat 17 August 2013 22:26
mach 3 setup help paul60 70. Control Systems 7 Tue 03 August 2010 11:02
Cannot get motor to turn - Mach Ports & Pins setup kalimero Troubleshooting 18 Tue 06 May 2008 09:50
Upgraded Mach, now the motors won't turn - Different ports/pins for later Mach Hugo Carradini Troubleshooting 19 Thu 25 October 2007 11:45
